injector hold down re-torque specs??
Old 02-09-2009, 03:01 PM
greagin's Avatar
greagin
greagin is offline
could anyone post a link to the process for re-torquing the injector hold downs and rocker boxes? i cannot remember the numbers and cannot find the thread i read when i did mine. i am trying to print it for a friend of mine as he would like to do his tomorrow. thanks in advance for any replies!!
Old 02-09-2009, 03:06 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Here you go Grant.
Old 02-09-2009, 03:43 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
Robin, not to hijack this thread but where are the glowplugs in that picture? I have to replace #7 and was going to re-torque everything, great picture and timing.
Thanks.
Old 02-09-2009, 03:56 PM
brian42's Avatar
brian42
brian42 is offline
Everything is included in this thread also. This is what I used yesterday...
https://www.ford-trucks.com/forums/8...ing-sound.html
PaysonPSD's Avatar
PaysonPSD
Thanks.
The white wires of the UVCH go to the GPs and they are just to the right of the injector connector. Can't really see them in that pic.
Here is a pic by Dan (Kwikkordead) that shows the GP connector connected to top of GP. Make sure your's aren't rubbing on the push rod like in this pic. That wire eventually shorted out on the push rod when the insulation wore away.
Old 02-09-2009, 05:23 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
10 foot pounds isnt nearly enough, usually they seat, and a few hundred miles they "seat in" and loosen up a little. Get the collar down over the top bolt, use a man's hand or a rubber mallet to get the injector seated, start the bottom bolt, a few smacks on the top with a rubber mallet, tighten it down tight with a 1/4" ratchet, then smack it some more with the rubber mallet, and recheck with a torque wrench, should be AT LEAST 10 lbs on it.
Old 02-09-2009, 05:29 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Glow plug torque? Not to many mentions on it.
Found 14foot pounds on the 1997 forums. Same on ours?
PaysonPSD's Avatar
PaysonPSD
Good advice Kris. Thanks. I will certainly remember this when I install new injectors.
Old 02-09-2009, 05:48 PM
PaysonPSD's Avatar
PaysonPSD
I have read 14 NM which equals about 124 in/lbs. I have also read 14 ft/lbs which equals 168 in/lbs. Anybody have a sure answer to this. I used 124 in/lbs when I replaced my GPs last Sep. No problems yet.
Old 02-09-2009, 06:15 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
14 lb/ft
Old 02-09-2009, 07:37 PM
PowerstrokeJunkie
I always put the glow plugs to 10-15lb-ft. Just snug and a little more basically.
Old 02-09-2009, 07:41 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by guzzle92
14 lb/ft
Good show Bob . Now the next time I'm under those VCs I will retorque the GPs as well as everything else.
Old 02-09-2009, 07:50 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
The guys at Swamps recommend injector to be as tight as you can get it with a standard 1/4 drive ratchet. They said they have seen more loose injectors from using a torque wrench. If its good enough for the injector builders its good enough for me!
Old 02-09-2009, 08:10 PM
F350-6's Avatar
F350-6
F350-6 is offline
I'll bet you $50 I can break one of those little bolts with just a 1/4" drive (we'll try this on your truck)
I don't doubt they've seen many loose injectors. That's why we're such a fan of re-torquing them. I've seen and read about how too much torque can have a negative affect on o-rings. Don't know if that holds true for the injector o-rings as well, but it's something to keep in mind.
Old 02-09-2009, 08:43 PM
truckeemtnfords
Thanks for all the additional info. Now I have another thing on the to due list when the weather gets better, finally got some snow and am looking forward to some sledding (snowmobiling).
DAJtheHunter
26
07-30-2017 08:43 PM
jimjokjv
28
07-17-2017 05:36 PM
BillyBob69
12-27-2016 03:17 PM
BombThreat
09-10-2015 09:51 PM
carl2591
18
09-08-2015 08:24 AM
Quick Reply: injector hold down re-torque specs??
