lower control arm
It's time consuming. Don't forget to take your shock off either If you can... use strut compressors or spring compressors to hold tension on the coil b4 you take it out. you will need to remove the swaybar links. Don't do what I did and remove the lower balljoint b4 removing the arm... that was dumb and a waste of time. If i remember right, you will need a deepwell socket to get the 2 inside frame bolts out. Once you put the spring compressor on, put a jack under the arm and put tension on the arm. remove the two frame bolts. IT WILL SWING DOWN VIGOROUSLY!!!! Be sure to be out of the way. Lower the jack and the spring is compressed, ready to reinstall. obviously take off ur spindle, shock, and related items. Hope this helps. Sorry for the jumbledness
I believe so. That's all I did to mine basically While ur at it, why not change the upper control arm and put in a camber/caster kit. Just a thought. On the sway bar link, you will have to remove it from both lower control arms now that I think about it. Other than that, you should be good to go. I did mine several months ago so I'm racking my brain trying to think if there's anything else. Not right now, but if I do, I'll post back here.
abcfisher1
1997-2006 Expedition & Navigator
06-24-2012 08:18 PM
jimkari
03-08-2008 10:02 PM
twallace
09-15-2004 03:10 PM
jessman1128
09-07-2004 10:04 AM
