223 head swap. Head bolt size difference
Can I use a later head on my earlier block? My block is bored for 7/16" head bolts. My rebuilt head is the newer 1/2" bolt size. I'm told the 302 hot rod guys use a special washer with a short bushing on the head bolt to bush a 7/16" up to 1/2" when fitting 351 heads on a 302. The washers are available at ARP fasteners. Sounds like it would work?? Any one done it?ThanksBob
C1TE6065A .. Bolt, Cylinder Head / 1/2" -13 x 4.44" / Fits: 1961/64 223 I-6.
B2AZ6065A .. Bolt, Cylinder Head / 7/16" -14 x 4.06" / Fits: 1952/60 223 I-6.
Not only is the head different, but...so is the valve cover & gasket.
The 1952/60 valve cover is held on by two nuts that thread onto two studs which protrude thru the center of the cover.
The 1961/64 valve cover uses 8 bolts around its perimeter to retain it.
I have a pal (Col. Flashman knows him too) that has a 1954 F100 with the later head. I'll have to call and ask him what he did to make it work.
Will post back when I find out later today.
Ford tractors in the 50's and 60's had the same situation. The early heads had 7/16" bolts and the later heads used 1/2" bolt. In the book they call it "new head to old block" and used shoulder bolts. They had 7/16" thread and 1/2" shoulder on top to take up the extra room. Ford part# D3NN-6065-A for the bolts. The book shows them to be 4.00" long. I don't know if they are still available. Dave
The last year Ford marked actual part numbers on parts was 1956.
Sorry, that might be right for automotive division, but not correct for ag. These ARE good part numbers. I called my local dealer this morning. #D3NN-6N014-A step down studs are $7.24 each. #D3NN-6065-A shoulder bolts are $24.21 each. 3rd and 4th digit NN numbers are very common in ag parts. Dave
62 squire
13
11-20-2013 06:15 PM
gman97005
08-17-2013 12:32 AM
gman97005
05-20-2013 11:48 AM
turnrjr
12-06-2008 08:51 PM
