shorties or long tube exhaust headers
i have a 99 f150 5.4L motor and getting it rebuilt and i am going to get some exhaust headers to replace the stock manifold
and what is the differance between the shorties and the long tube headers
what porformance gains
any fit problems
and mainly after fit sound?
any fit problems
Header will even out the distance that the exhaust travels to meet at the collector for all cylinders. With all tubes being the same length, exhaust performance goes up as does power. Shorties will help more with high end (loss in mid and low range) and long tubes will help boost low and mid range power. I had a set of shorties (JBA) on my '97 5.4L F-150 and was pleased with their performance and quality (lasted 10 years and sold it with them still on). When I bought the truck in '97 the only thing I could get was shorties (not much room in the engine compartment), but maybe somebody has come along in the last decade to make some longer tubes.
Long tubes all the way....had both and the LT's pack a larger punch all the way through the rpm range. There only 2 kits available that have the complete bolt on with a y-pipe...Dynatech, and OBX which are Dynatech knockoffs. Both are made of high grade SS and fitment is great. If you want the best then look at a set of Kooks, but the are mucho $$$.
Im pretty sure you have that backwards. Shorties produce bottom end while long tubes produce high end.
so this leaves you in a bit of a quandry! give up bottom end for some top end or get more bottom and have less top? my mods so far (fan, tuner) seemed to add low end mostly, but would that be negated by adding LT? This was actually my next planned mod and I thought I would go LT, but now I wonder.....
With shorties you wont loose top end, you just wont gain any over stock manifolds. ( Corrrection, depends on how bad the stock manifolds are, they could still produce more power everywehre) Long tubes offer the largest gains, most of which is Mid-Top end. With loss's in the bottom RPMs normal due to the loss of back pressure.
The Kooks are cheaper then the Dynatechs.
OBX are even less $$$.
