1991 F-150 Auto Trans, computer controlled?
My donor truck for my 4.9 to 5.0 conversion in my 94 F150 (M5OD) is a 1991 F150 with an automatic. I originally thought it was a 1990. We pulled engine and trans (and rear-end) today. I want to use the computer and engine harness among other things for the 5.0 I'm building.
I noticed that there is one small harness going to trans, looks like 2 pins. Is this for the speedo? Auto trans in a 91 is not computer controlled is it?
Also has a small harness, looks like 2 pins, going to rear-end. I plan on using rear because its a 3.55 posi. Whats the wires at rear-end for?
Thanks
Thanks
on
2 wires to the tranny are probably gear indicator(computer wants to know when it's in drive or park), the rear end has a RABS sensor in it and in some trucks this was also uses as the speed sensor. Does the tranny have a speedo cable attached? There should be a tranny code on the drivers door pillar, this will tell you what the tranny is for sure.
on
There were 3 differernt possible 4-speed auto trannys available for this era truck, the AOD, 4R70W, and E4OD, so it's impossible to say with certainty what you have. The last 2 were computer controlled and will have a multipin electrical connector attached to the tranny, so if you don't have this it's most likely you have an AOD.
OK, Paul here is what I have:
Trans code off of the data plate is 'T'. Connector into trans housing just above valve body looks to have 4 pin connector. Speedo cable goes into the tailshaft like a normal trans. I have a bunch of other numbers off of the tail shaft. I've tried to find a decoder on the net but cant tell for sure if this is an E or not.
If it is an electronically controlled E4OD......can I use computer and harness for the 5.0 in front of the manual tranny?
Rear-end code off of plate is H9N which I believe translates to a 3.55 posi, is that what you have?
Thanks for your continued help,
Craig
Craig
Thanks Paul, I've been really re-thinking this project. I'm wondering if I shouldnt just go ahead and use the auto tranny anyway. I've got everything I need from the donor truck, radiator, all mounts etc (am I missing anything?). My kid would prefer the manual but the old man is sponsoring it so I have the final say! A B&M shifter would look pretty cool on the floor and with the warmed over 5.0 and 3.55 should be fun to drive.
Any thoughts? Anyone......Anyone...... Manual or Auto?
50SICKS
12-06-2013 09:24 AM
nofortunateson
1983 - 2012 Ranger & B-Series
19
12-31-2007 12:13 PM
