What Steering Column Did you use?
I have a 48 f1.I have a 1972 ford truck column I'm planning on using in it.I just wondered what everyone else used & how much work it took to make it work, and how you mounted it to the floor.My column came put of a 1972 4X4 w/4 speed tranny.It is not a tlit wheel but looks like it will work fine.I just have to move the hanging mount and make a floor mount.
ART
ART
I used a tilt column from 1978 Chevy van. I had to redo the top mount because the column is bigger dia. I just made a bottom mount. My problem is I want to use the column shift to run an auto transmission, but I have the original brake pedal and I believe I will have problems with the two interfering. Lokar makes a cable type column shifter assy that I think will solve the problem. Dave
Mine is out of a 94 Caprice, it is the same coulmn as the GM truck unit but it had an air bag so you have to remove the clock spring and machine a spacer for it. They are about half the price of the truck or S-10 and I am cheap. I am using a coulmn shifter so I had to cut the shift tube and bearing end off and rotate it 90 degrees to clear the exhaust and brake pedal. I used an old aluminum conecting rod for the drop that I cut and tapped to accept 5/16" studs and used the stock mounting holes in the dash.
Mike
Mike
lefty rodan
03-26-2023 10:56 PM
1oldtimer
06-17-2010 02:31 PM
theGman
10-27-2005 09:40 AM
bradoemba
04-21-2005 10:48 PM
