1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
A/C Hose assembly leaking
Old 01-13-2009, 08:38 PM
boffah's Avatar
boffah
boffah is offline
It is just the hose closest to the groung (with metal clamp). It is leaking, but I'm not sure if I can tighten/seal the leak, or if I have to but the whole assembly?
Any ideas?
AutoZone.com | Shopping | Parts | Product Detail - A/C Hose Assembly
While we find your parts, please enter your ZIP Code at PartsAmerica.com
Old 01-13-2009, 08:49 PM
boffah's Avatar
boffah
boffah is offline
The one side comes from the radiator, then goes through the metal cylinder, then out, and then the leak is where that output hose then butts up to the metal - I can see the tear in the hose... spraying a fine mist of coolant...
The torsion belt is also frayed to hell where the mist must have hit during tearing/bursting...
Old 01-13-2009, 09:44 PM
boffah's Avatar
boffah
boffah is offline
The leak is on this hose, back where it meets the other metal clamp.
Old 01-14-2009, 06:11 AM
boffah's Avatar
boffah
boffah is offline
See the lower left of the picture above, that is what it looks like at the other end where the leak is. Is there some type of clamp/tape or means of replacing just the hose?
Old 01-14-2009, 04:22 PM
Freak4Ford's Avatar
Freak4Ford
Freak4Ford is offline
Unless you have the proper equipment to evacuate and recharge your A/C system, its highly recommended that you have a qualified tech replace your hose and possible o- ring. Any refrigerant in your system will need to be recovered first before the system can be opened for repairs.
Old 01-17-2009, 04:05 PM
boffah's Avatar
boffah
boffah is offline
It appears the only way to fix this is to buy the whole assembly ($100-200)... Do they make a hose repair kit that would work for this... it is a very small tear, which was caused by a frayed torsion belt that repeatadly smacked the hose
Old 01-17-2009, 04:07 PM
boffah's Avatar
boffah
boffah is offline
Amazon.com: Slick Wrap Pipe & Hose Repair Kit (PW260): Automotive
up to 300psi... what is the max pressure for that hose?
Old 01-18-2009, 09:25 AM
lsrx101's Avatar
lsrx101
lsrx101 is offline
That hose is rated for about 600psi or better but the highest pressure it sees is about 250-275. It also sees high temps from the hot liquid refrigerant.
You know what you need to do, you just don't want to believe it. (I know the feeling). You can try the repair kit, but ultimately you will have to replace the hose assembly. Anything else will just be throwing money away.
The only other real option is to remove the hose assembly and take it to an AC shop or a local NAPA that does AC lines. They may be able to replace the damaged rubber.
Either way, you will need to have a shop evacuate and recharge the system.
Old 01-19-2009, 04:21 PM
thecardoc's Avatar
thecardoc
thecardoc is offline
You can buy the complete hose assembly from the larger parts stores . Napa has it for about $225.
Tobnpr
08-18-2016 12:29 AM
Eric H
02-09-2011 01:56 PM
tomtoc
09-12-2007 09:56 AM
460me
11-21-2005 09:06 PM
bshackelford711
07-01-2005 01:56 PM
Quick Reply: A/C Hose assembly leaking
