single to dual exhaust
Old 11-20-2002, 01:46 PM
gonzoloco's Avatar
gonzoloco
gonzoloco is offline
I have a 1991 E-150 van with single exhaust and i'm converting it from single to dual system from font to the back and I want to know if i need to install a balance pipe between the two sides.
Old 11-20-2002, 01:58 PM
akford351's Avatar
akford351
akford351 is offline
Welcome to FTE...
Unless you are going to go true duals... from the manifolds back. Then an h-pipe or x-pipe is not necessary. If you are then it will be needed to balance out the exhaust pulses and increase torque--
Ray
Old 11-20-2002, 02:35 PM
fordtruckin's Avatar
fordtruckin
fordtruckin is offline
You don't have to, but it will mellow out the sound, as well as add torque.
Old 11-20-2002, 06:11 PM
dpoelstra's Avatar
dpoelstra
dpoelstra is offline
why go to true duals? A single 3 inch pipe flows more then dual
2 1/2 inch pipes anyway, plus it's easier and cheaper.
Old 11-20-2002, 07:35 PM
gonzoloco's Avatar
gonzoloco
[updated:LAST EDITED ON 20-Nov-02 AT 08:50 PM (EST)]yes , I'm going to run true dual from the header all the way to the back, so do i stilll need the install the balance pipe. yes or no and why and what is going to do to the emissions.:-)
1991 econoline E-150 conversion van with K-N air filter,Ford racing headers, dual from the muffler back, also 18x8.5 chrome wheels and fat tires, bosch4 spark plugs, 9mm wires and a nice stereo system.and also i bought flowmaster muffler anb magnaflow cats that i need to install
Old 11-20-2002, 09:52 PM
fordtruckin
It won't do anything for emissions. It is not required to have a balance tube, but there is no reason not too, it sounds better, gives better power and is very cheap.
Old 11-21-2002, 12:10 AM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
justcruzin125
07-08-2016 10:49 PM
edreckers
08-11-2015 04:13 AM
bchunter
Exhaust Systems
12-30-2004 08:34 PM
tonga3
Exhaust Systems
06-09-2003 02:50 PM
betsy
Exhaust Systems
03-02-2001 11:53 PM
Quick Reply: single to dual exhaust
