Wheel offset? '04 = '06?
01-06-2009, 09:03 PM
on
Is the wheel offset the same for an '06 to an '04? I am looking at buying some wheels from a guy with an '06 to put on my '04.
Thanks!
01-06-2009, 09:06 PM
No.
99-04 is different than 05+.
More Back Space on 05+ so they sit further under the truck/closer to the leaf springs when mounted on a 99-04 4x4.
To run 05+ wheels on a 99-04 SD you need wheel spacers (high quality billet steel, hub-centric....approx $350 per pair).
01-06-2009, 09:32 PM
on
Thanks! Out of curiosity who makes them and what is the thickness. I'm not gonna buy them unless he lowers the price to offset the cost. Which i doubt he'll do. ( I wouldn't!)
01-06-2009, 09:36 PM
01-06-2009, 10:10 PM
A 1.5" spacer would be more then enough. You really only need 1.32" to bring the wheels back to stock positioning...
01-06-2009, 11:13 PM
need closer to 2 in so you dont have to cut the studs though
the spacer/adapters bolt to the hubs then have there own studs
so you have 16 lugs per corner
if the spacers are 2 inch you dont have to cut the original studs shorter
01-06-2009, 11:16 PM
on
Thanks for all the replies!
sbeamer
1999 to 2016 Super Duty
12-05-2015 02:49 PM
Lgilliland
04-06-2015 03:32 PM
JR250R
Offroad & 4x4
05-11-2014 06:17 PM
ruger761
08-11-2012 03:06 AM
cattlerancher
2004 - 2008 F150
07-13-2011 07:01 PM
