1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Flushing tranny with royal purple
Old 01-04-2009, 09:17 PM
995.4SD's Avatar
995.4SD
995.4SD is offline
I am going to flush the tranny this week with Royal Purple and can't decide how i want to do it. I changed the tranny fluid the spring before last (25K miles ago). I drained it and changed the filter, then drained and re-filled about 2 weeks later to get the TC fluid out. Now i want to put royal purple in this time and wondering if i should go ahead and change while im at it. doing a search here i guess its not too common to change the filter at every change, thats why i ask. It sure would be nice just to disconnect the output line, fire it up and pour the fluid in the dipstick...but for peace of mind i am thinking about changing the filter. what do you think?
Old 01-04-2009, 09:30 PM
dew the thunder's Avatar
dew the thunder
dew the thunder is offline
I change the filter every time I pull the tranny pan. A little preventative maintenance for a pretty small price yes?
Old 01-04-2009, 09:34 PM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Or you could go with the external filter kit, just spin on a replacement. Diesel Manor and other places have it, costs about $119.
Old 01-04-2009, 10:09 PM
995.4SD's Avatar
995.4SD
995.4SD is offline
no doubt i would change it if i was for sure pulling the pan, but i can flush it without touching the pan. i will most likely end up changing the filter just want to hear what everyone here does.
Old 01-11-2009, 04:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
I don't change the filter every time. Here's how I recommend changing the fluid.
https://www.ford-trucks.com/article/...nsmission.html
Old 01-11-2009, 06:02 PM
Steve_250's Avatar
Steve_250
Mark,
Does your article need updating?
You wrote to use ATF, not Mercon V.
That counters this TSB:
M/T - Mercon(R) V ATF Usage Information
TSB 06-26-1
01/08/07
MERCON ATF IS BEING REPLACED BY MERCON V
AS A SERVICE FLUID FOR SOME MANUAL
TRANSMISSIONS FORD:
1981-2003 Escort
1984-1995 Thunderbird
1985-2007 Mustang
1985-1996 Bronco
1985-2007 Ranger
1986-1997 Aerostar
1991-2004 Explorer
1995-2007 F-150
1996-2007 F-Super Duty
2001-2003 Explorer Sport Trac, Explorer Sport LINCOLN:
2001-2002 Lincoln LS MERCURY:
1984-1995 Cougar
1987-1999 Tracer ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as the service fluid for manual transmissions originally requiring MERCON(R). ACTION
Beginning immediately all manual transmission applications requiring MERCON(R) can now be serviced using MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V. After July 1, 2007, MERCON(R) Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will continue until remaining inventory has been depleted.
Old 01-12-2009, 10:48 PM
Mark Kovalsky
Yes, the article needs updating. I don't have a way to modify the article.
