Lightning Traction Bars
Old 12-30-2008, 05:22 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Question Lightning Traction Bars
Does anyone know if the 1st gen "L" traction bars will fit on a regular 2wd? I have a pair that I got for a good deal and thought that it would be a cool mod. Are the only components the snubber bars and the mounting plates? It looks to me like they won't work because of the hole for the pin on the leaf springs. If the pin goes into the snubber bar there won't be a pin in the spring perch on the axle.
Old 12-30-2008, 09:10 AM
jonwoos's Avatar
jonwoos
jonwoos is offline
On my 93L, the the spring pack bolt went thru all the springs,and the snubber leaf to clamp them ALL together. The bolt head then goes into the spring perch on the rear-end. For the snubber to work better once installed, you need to shim the rubber bumper up to the leaf, have them touching. I hope I helped you.
Old 06-02-2009, 12:28 AM
TexasGuy001
Has anyone else done this? I really wanted to be able to use these.
Old 06-02-2009, 09:12 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I doubt it will. The lightning springs are flatter and the snubber almost touches the spring just sitting. In a regular F150 the springs are going to have to wrap in order for the snubber to touch. Just my .02 cent
Old 06-02-2009, 09:17 PM
86F150302's Avatar
86F150302
86F150302 is offline
edit: misread
Old 06-03-2009, 08:49 AM
TexasGuy001
I guess I'll just sell them to a 1st Gen Lightning owner.
Watcher58
12-01-2015 01:14 AM
Freightrain
21
10-12-2015 01:40 PM
skoveng
1999 to 2016 Super Duty
07-04-2013 01:16 PM
t_hess66
06-03-2011 03:33 PM
EMC V10 X
11-20-2010 11:46 AM
Quick Reply: Lightning Traction Bars
