Where are all the Nubee's?
Hi Bill,
They are probably afraid to. If they are not all knowing, and happen to ask a question that has been answered before or do not know to give enough info. the responses can be rather rude. Or maybe they just have no idea what they are doing and are as green as grass to these old trucks, or any other vehicle. But they are willing to try to learn. They are the ones that should be able to ask and get a straight answer with out being treated like they are stupid. They deserve credit for having the guts to jump in and try. Just my opinion.
Bill T.
Bill T.
Hi Bill,
Bill T.
Bill T.
I'd have posted earlier but have been wresling with the clutch on my Ranger. First time doing this so it has been slow.
First the drive shaft didn't want to come off, found out you need a BFH. Took care of that problem.
Didn't drain the oil so took a bath once the drive shaft came out.
Waisted an hour or so with a "helper" and "advice" trying to remove the Y.
Came back next day (doing this at work, I have a gravel drive and no garage) after reading hear and finialy got the trans out myself.
Pilot bearing (if you can call it that) was non existant except the outer shell. After trying to find a puller, and the grease ext trick (to no avail), the chisel and BFH took care of the bearing.
Now the new flywheel doesn't quite match up, 4 holes good, 2 slighly off.
Will give it a go again Sunday or maybe a day off wouldn't be bad. I do have 2 wheels to boot skoot n boogy.
Hi, Keep rotating the clutch plate around untill all the holes line up, sometimes the bolt holes are offset, don't know if that's the case with your truck or not but might be worth a try. I am sure i have ran across what you describe before..... Aint Gravel fun!
Just a month ago I poured a 10X20 ft concrete pad, so no more dirt for me!
What kind of bike?
What kind of bike?
Received 3,697 Likes
on
What kind of bike?
What kind of bike?
I took today off due to football, gotta keep your prioritys straight. Although I should've done something else considering Pitt didn't bring home the bacon, and don't know what the h@^% the Cardinals were playing(not football).
I'm hoping someone will turn me in for extreme house makeover, maybe I can get my garage. Gravel definately pushes some maintenance items out a bit.
As for the bike I ride a Honda Shadow for a daily commuter (sorry Harley guys).
On dirt I race a KTM.
