roof marker light - clear lenses or LED ?
Check out some Recon lights for a 03-07 dodge. Those will fit and cover the holes from the stock lights.
The first link you posted are Superduty lights and look great on trucks that don't have cab lights already. I put some on my 95 and they work and looked great. I want to upgrade my 97's with some smoke lights and I will be using the Dodge lights from Recon.
I put clear cab lights on my truck. I used the recon ones for a 99-02 dodge. I got the idea from another member on FTE i think his name is FordF350??
He told me too use the dodge ones for a 99-02. Im not sure if the dodge 03-09 lights are the same size as the 99-02. The only difference i can tell by looking at the pictures on recon is that the screws that mount the lights to the roof on the 99-02 lights are on the sides while the screws for the 03-09 lights are on the front and rear of the lens.
I would recommend you guys get the lights for a 99-02 dodge because i guarantee that they will cover all the holes on the roof from the stock ford cab lights.
I dont have any pictures of my truck with the dodge cab lights on but if anybody is interested ill run outside here in a bit and take some pictures. I think the dodge lights look alot better than the stock ford ones.
on
Sorry i kinda forgot about getting the pictures. I ended up working right through the weekend and ontop of that im hunting for a new job so ive been really busy.
I just remembered about this thread so i ran outside to take a couple pictures...the only problem is its dark here so they probably arent the best pictures but it give you a idea.
http://img.photobucket.com/albums/v3...rguy89/193.jpg
http://img.photobucket.com/albums/v3...rguy89/194.jpg
http://img.photobucket.com/albums/v3...rguy89/195.jpg
http://img.photobucket.com/albums/v3...rguy89/187.jpg
lee00
03-09-2015 08:20 PM
FordOwnerJoey
01-21-2014 08:35 PM
sparky69
07-25-2005 12:09 PM
