Old 11-17-2014, 06:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Champion 7989 Spark Plugs
Old 02-06-2014, 10:04 PM
cb_13's Avatar
cb_13
cb_13 is online now
I would rather change motorcraft plugs at 100k than champions at every 30k. Just my preferance.
  #32
Old 07-22-2014, 06:18 PM
Youngray's Avatar
Youngray
Youngray is offline
Motorcraft
So did Motorcraft come out with a one piece? I'm about to replace my COP's and wanted to change the plugs while was I there.
  #33
Old 07-22-2014, 07:03 PM
ramhunter5877's Avatar
ramhunter5877
ramhunter5877 is offline
Hi way men
What did they do for all that money?
  #34
Old 07-22-2014, 08:44 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
This is a 6 year old thread with 32 previous posts before you posted, so to whom are you asking that question?
Stewart
  #35
Old 07-22-2014, 10:17 PM
rickh6155's Avatar
rickh6155
rickh6155 is offline
Pulled the right head off, tapped out very gently the piece that broke off, and put everything back together. Very time consuming and thus very costly.
  #36
Old 07-22-2014, 10:23 PM
rickh6155's Avatar
rickh6155
Not to my knowledge. The Champs are far superior in my opinion, and they are platinum plugs, so the replacement mileage is comparable to the OEM Motorcraft plugs. I'm on my second set now, and no major issues whatsoever. The first set even came out easier than the Motorcraft originals. I highly recommend them. Truck just turned over 200,000 miles an perking along just fine.
  #37
Old 07-22-2014, 10:24 PM
rickh6155's Avatar
rickh6155
Champs are platinum as well. Same mileage interval on changeout as Motorcraft.
  #38
Old 12-11-2016, 04:51 PM
Ted928's Avatar
Ted928
Ted928 is offline
I just installed my second set of champions. I was replacing fuel injectors since I recently read that the 2005 had bad injectors which can destroy the motor so I figured it was a good time to change the plugs also. The first set had 60,000 miles and 6 years on them. I was glad that they are welded as it took a lot of torque to get them out, even using carb cleaner. I checked the gaps and they were less than 44 mils which means no opening. I tore one boot. Spraying WD40 down the center of the boot didn't help. Then I used a hard wire down the center of the boot to break the seal and then they came off.
mig25
1997-2006 Expedition & Navigator
117
01-12-2023 12:46 PM
David_h
Modular V8 (4.6L, 5.4L)
10-08-2017 02:57 PM
David_h
1999 to 2016 Super Duty
06-22-2017 07:19 AM
olblue77
2004 - 2008 F150
04-24-2016 01:45 PM
olblue77
04-17-2016 11:30 PM
Quick Reply: Champion 7989 Spark Plugs
