Ford F-150/F-250: Spark Plug Reviews
How do you choose the right spark plugs for your Ford F-150 or Super Duty? With a lot of options out there, we break down the most popular ones in detail for you.
By Brett Foote - October 30, 2014
This article applies to the Ford F-150 (2004-2014) and F-250, F-350 Super Duty (2005-2014).
Spark plugs are something that you don't have to replace very often, but they play a big role in how your F-150 or Super Duty performs every day. On any kind of plugs, sparks like to jump from the sharpest point on the center electrode to the sharpest point on the side electrode. Plugs that retain a sharp edge for a longer period of time are typically made out of platinum or iridium, because these materials are harder than copper and have lower melting temperatures. This is part of the reason why platinum and iridium have become a popular choice among buyers. For a little extra money, you can buy a set of plugs that will perform better and last longer. The average copper spark plugs last from 10,000 to 20,000 miles, while the more expensive iridium or platinum can last 60,000 to 120,000 miles.
Motorcraft
Autolite
NGK
Champion
Bosch
Price $3-12 $2-11 $3-14 $2-14 $2-5
Material
Platinum, Copper
Platinum, Copper
Copper, Iridium, Platinum
Weight 2.4 oz 1.8 oz 1.6 oz 0.8 oz 0.8 oz
Life 60-100,000 miles 100,000 miles 100,000 miles 60-100,000 miles 60-100,000 miles
Thread Size 16 mm 14 mm 14 mm 14 mm 14 mm
Warranty 1 year 2 years 1 year 1 year 1 year
Best Quality: NGK
Best Value: Bosch
Motorcraft
Price: $3-12
Material: Copper, Platinum
Weight: 2.4 oz
Life: 60-100,000 miles
Thread Size: 16mm
Warranty: 1 year
Motorcraft is a brand that carries a stellar reputation across internet forums, and for a good reason. Their parts are owned and distributed by Ford itself, and are made to the exact specifications for their vehicles. These are good quality parts at attractive prices, which makes them hard to beat. Motorcraft spark plugs are a great choice, especially if you opt for platinum, unless you are running a highly modified engine. Plus, they will likely last the life of your truck. Recommended if you are looking for good quality parts that will last the lifetime of your truck.
Autolite
Price: $2-11
Material: Copper Platinum
Weight: 1.8 OZ
Life: 100,000 miles
Thread Size: 14 mm
Warranty: 2 Years
Autolite plugs offer great performance and long life at a low price. Many forum users report a slight increase in gas mileage and performance in these plugs over stock ones. Many users also report a smooth idle, increased responsiveness, and a small increase in power. While you can't go wrong with Motorcraft, Autolite will save you a few dollars and provide nearly identical performance. Recommended if you are looking for great performance and long life at a more affordable cost.
NGK
Price: $3-14
Material: Iridium, Copper, Platinum
Weight: 1.6 oz
Life: 100,000 miles
Thread Size: 14 mm
Warranty: 1 year
NGK spark plugs provide the benefits of a slow wear rate and long service life when purchased in iridium or platinum, and have excellent anti-fouling characteristics. NGK plugs have a reputation for being an excellent choice at a great value. Buyers report a noticeable increase in performance, a smoother idle, and better gas mileage when using NGK plugs to replace stock ones. Clearances are noticeably tighter because NGK uses laser-welded technology. Recommended if you are looking for slow wear rate and improved performance at a great value.
Champion
Price: $2-14
Weight: 0.8 oz
Thread Size: 14 mm
Warranty: 1 year
Champion plugs are often cheaper than the rest of our competitors, depending on which material you select. Most Champion plugs can be owned for $2-$4 each. Though the company itself has been in business for over 100 years, they don't have a great reputation among forums. Many buyers have reported having problems with failed plugs after only a few thousand miles, though others had better luck. It seems to be a roll of the dice, one that isn't really worth saving a little money up front for. Recommended if you are looking for affordable plugs.
Bosch
Price: $2-11
Weight: 1.8 oz
Life: 100,000 miles
Thread Size: 14 mm
Warranty: 2 years
Bosch spark plugs are very affordable, but surprisingly well regarded in the internet forum community. You can buy a quality platinum Bosch plug with surface air-gap technology that improves spark performance for less than $5. Buyers rave about the quality, improved gas mileage, and absence of the need to regap. Other accolades include improvements in smoothness and better burn through. Recommended if you want solid quality and improved gas mileage at the lowest price.
Related Discussion
