Head R & R - Ford Truck Enthusiasts Forums
Head R & R
Old 12-11-2016, 04:47 PM
Lane Locke Lane Locke is offline
Lane Locke is starting off with a positive reputation.
Head R & R
2005 F150 5.4L. with coolant in oil. Have not done compression tests or leakdown tests yet but want to be prepared for the ordeal if I need to replace head gaskets...
Can the heads be removed without removing the camshafts?
Timing chains, sure- but the actual cams themselves?
Old 12-12-2016, 08:07 AM
Found the answer on another forum....
Old 12-12-2016, 10:46 AM
fordiesel69 fordiesel69 is offline
fordiesel69 is starting off with a positive reputation.
What was the answer, I am also interested in knowing.
Head gasket MI02SVT 1994.5 - 1997 7.3L Power Stroke Diesel 5 04-19-2016 05:18 PM
351w High idle and smells rich jdthedj10 1987 - 1996 F150 & Larger F-Series Trucks 4 01-11-2016 04:15 PM
exhaust stud removal trick rock2610d Modular V10 (6.8l) 12 08-07-2015 10:27 AM
Help with V10 head removal, please. chellaman Modular V10 (6.8l) 8 10-18-2012 04:55 AM
4.2 Head Gasket Removal pahje1 3.8 & 4.2L V6 12 08-29-2004 03:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
