1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 F250 swapping from paddle side mirrors to tow mirrors
Old 12-09-2008, 12:53 PM
gbmarine's Avatar
gbmarine
gbmarine is offline
I have a 2005 F250 with power paddle mirrors and would like to swap them for the telescoping tow mirrors with heat and turnsignals. Does anyone know if the 2005 is pre wired to accept these mirrors or will I need to get the tow mirrors without the heat and turnsignals? I have heard that the truck comes pre wired but would like to be sure before purchasing the mirrors. Thanks for any info on this topic.
GBMARINE
Old 12-09-2008, 02:16 PM
patrickke's Avatar
patrickke
patrickke is offline
if you look there are a few threads about this and they appear to be easy to wire up if you by chance dont have one that is prewired and I believe that they have have some wiring diagrams too on the threads
Old 12-09-2008, 04:06 PM
Layson's Avatar
Layson
Layson is offline
I am sure it is plug and play for the adjustments... You probably will have to wire the lights, turnsignals, and heat for the mirrors. Piece of cake though. Just tap into the wires up by the headlight and just a (+) ignition source for the heat..
Old 12-09-2008, 06:42 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
All the wiring is there no matter what mirrors you have. However, they did have a few different connector variations. Worst case scenario the connectors wont match and you will have to get the adapter harness' or just hard wire them like I did.
Old 12-10-2008, 12:23 AM
WildWildWest's Avatar
WildWildWest
WildWildWest is offline
I swapped a set of 2006 chrome trailer tow mirrors in for my 2005 paddle mirrors and they were plug and play. Not sure what year they changed the plugs, but if you get a set of power towing mirrors from 2005 to 2007 they will be plug and play for your truck when it comes to turn signals, heat and power...and you will enjoy them. I am now considering the next level of upgrade - the '08/'09 tow mirrors as it sounds like the vision is even better!!
Old 12-10-2008, 08:20 AM
gbmarine's Avatar
gbmarine
gbmarine is offline
Thanks for all of the info as it will be a great help and I am going to get the tow mirrors with power, heat and turnsignals. I will add to this once I have completed the job with more details on anything that may be helpful for anyone else doing the swap. Thanks again.
GBMARINE
Old 12-20-2008, 07:30 PM
gbmarine's Avatar
gbmarine
gbmarine is offline
I just finished receiving and installing the new tow mirrors. My original paddle mirrors were power only....no heat, turn signal etc. The new tow mirrors are power, heat, parking light and turn signals. They were plug and play for me and the entire job start to finish took just under 2 hrs. Thanks again for the help, they look great and more importantly they work great and towing is a pleasure.
Old 12-21-2008, 10:06 PM
bayou barataria's Avatar
bayou barataria
bayou barataria is offline
I bought a set for my 08 250, and they were plug ready, even for the heat circuit, they are pricey, got them from the dealer.
Old 12-24-2008, 10:41 PM
Ftree50's Avatar
Ftree50
Ftree50 is offline
gbmarine, do you have a link for where you got them? i was looking at getting the painted ones, but the black are fine too..
Old 12-25-2008, 10:27 AM
Super08's Avatar
Super08
Super08 is offline
Just as long as you have the power paddle mirrors then everything will be pre-wired and it will be plug and play. I changed mirrors on my 05 as well as I needed the towing mirrors.
Old 06-03-2011, 11:04 PM
878ranger878's Avatar
878ranger878
878ranger878 is offline
I have a 01 f250 XLT with power paddle mirrors. wanting to get the tow mirrors with blinkers as well. After running the mirror blinker wire through the door panel where do i splice it to? Where is the best place to access my trucks blinker wires? Also if i wanted to do this, this means i would have to run wires from the mirror then door panel then from the door to my truck body through that black tube in the opening of the door?
Old 06-04-2011, 10:32 AM
Livn-lg's Avatar
Livn-lg
Livn-lg is offline
Overhead console and Computer
sorry. posted in wrong place
thkohlb
11-15-2014 10:17 AM
darbyt
08-31-2013 09:05 AM
Rob.D
2009 - 2014 F150
21
11-18-2012 02:46 AM
878ranger878
06-17-2011 01:56 PM
edub32
03-03-2011 09:09 AM
Quick Reply: 05 F250 swapping from paddle side mirrors to tow mirrors
