I am still looking for help with my 2000 f-250 v-10. it has a slight miss at idle and just belches wjite smoke from un burnt fuel.
i changed plugs and 1 COP about six weeks ago and truck has run run great,but started loading up with fuel and slight miss at idle. truck runs good once you get up to around 60 mph. i have changed fuel filter,fuel pressure regulator,TPS and nothing has helped. Back when i changed plugs 6 weeks ago i took injectors to shop and had tested and they di not even think they needed cleaning. soooo??? I am looking for all the help i can get. thanks
I have just changed plugs and cyl #9 was fouled with gas,just like it was 6 weeks ago when i changed them.Compression is good,injector is good. ????? anyone with an idea,why this one cylinder wants to foul out. i have shuffled all of th COP's around to see if the problem moved but it comes right back to this cylinder.
My problems started 6 weeks ago when it blew the plug out of this same cylinder.I replaced plug and coil,but still had miss.I later found that the wires that connect to COP had a broken wire,so I ordered a new wire pigtail and installed and now this cylinder is again dead???
