It helps regulate the amount of air entering the engine at idle.
Hey Thanks alot Man....I think mine is malfunctioning due to shut off's after start up. Read on another thread someone else had the same problem. Again THANKS!!!!
No problem.
Mine was making an intermittent hum at idle, even thought the truck idled fine. Was just annoying. I cleaned it, and it did great for a day, then hummed all the time when slowing down close to idle, and at idle. Replaced it, and all is good.
