Choke Relay Sources? 86 Bronco
1986 Bronco Winsor 351, Electric Choke. Holley 4180
Choke has very little voltage at spade terminal on choke cover. 1.0 volt dc.(wire removed an measured dc to ground) goes to 0 volts dc when connected.
Traced wire from choke to relay on drivers side firewall. Is this a Choke Voltage Relay? If so, can anyone tell me where I can get a replacement unit. Any suggestions? What is its proper name for the relay?
Choke is not working properly. Stays closed, cleaned with carb cleaner.
Anyone have a wiring diagram of choke electrical circuit.
Is this just 12v dc switched? Or something less??
Thanks Bob
I checked major web sites for Choke Relay, but no luck, maybe its called something else.
Thanks Bob
Thanks Bob
Thanks Bob
chafin1960
13
06-18-2016 02:21 PM
Mdc9966
09-16-2015 11:20 AM
86rustbucket
03-13-2008 06:41 PM
