Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-27-2008, 05:06 PM
kjsway kjsway is offline
Garage is empty, add now
kjsway is starting off with a positive reputation.
Talking Fog Light Bulb Replacement
I've got a burned out bulb on one of my '07 Expy fog lights. Getting under the truck does seem to yield any obvious way to get at the bulb out from the front or back of the fog light. Are the factory fog lights sealed where you have to replace the whole unit or can you access the bulb? Any tips to remove the bulb or whole unit? Thanks.
  #2 (permalink)
Old 11-28-2008, 02:56 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Page 91 of my '07 Expedition owner's manual:
Replacing foglamp bulbs
1. From underneath the vehicle,
rotate the harness/bulb assembly
counterclockwise, to remove from
the fog lamp assembly.
2. Carefully disconnect the bulb
from the harness assembly via the
two snap clips.
Install the new bulb in reverse
order.
-- Chuck
  #3 (permalink)
Old 11-30-2008, 10:58 PM
bjtor bjtor is offline
bjtor is starting off with a positive reputation.
Changed the fog light bulbs on my 08 last month. They were hard to break loose, but I got them turned and it was easy to pop the new bulb in and replace the assembly.
Replaced the stock bulb with the Sylvania Silverstar and they are much brighter.
good luck
  #4 (permalink)
Old 12-02-2008, 03:57 PM
Thanks for the information on the removal and bulbs.
K.J.
Tags
1999, 2005, bulb, bulbs, change, changing, expedition, f150, fog, ford, light, lincoln, navigator, removal, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
