351w sounding sort of like a diesel??
I was reading another post and came across another probable issue with my truck. My '89 f250's motor (351w) sounds like a "quiet diesel" so to say. I have checked for exhaust leaks, none found. The fan clutch is seeming to be engaging/disengaging the way its supposed to be. Is this a common sound for these trucks? I have a glasspack exhaust on the truck and ALWAYS hear the motor over the exhaust at both high and low RPMs.
Also, im still having the issue with the gas mileage on this truck. Its getting 7 to 8 mpg with a mix of town/highway miles(only about 40 miles on highway). I took my 33x12.50x16.5 tires off to see if this would get any better, and low and behold, it didn't. Any suggestions?
And i have heard the PLatnium plugs aren't the best for this truck. I was told to go back to the motocraft coppers. any input on all this ?'s will be appreciated.
Vehicle Specs:
1989 F250 w/ 351w
4.10 gears
fuel injected
K&N FIPK intake
autolite plugs and wires (Platniums)
C6 tranny
All fluids are full synthetic
31,000 org miles
245/75/16 BF goodrich all terrains
Vehicle Specs:
1989 F250 w/ 351w
4.10 gears
fuel injected
K&N FIPK intake
C6 tranny
31,000 org miles
Yes, it has two tanks.... and the sending unit for the fuel gague doesn't work for the front tank. Idk if there is any rust or anyhting in the tank, so i dont use it. The gague always goes wayy past the full mark on the front tank. I should probably block this tank so there is no cross flow. Is there a way to do this? Or should i just replace the tank and the sending unit?
The fuel filter was changed about a month ago... Maybe ill just take it to a shop and have them do some tests and run some diagnostics and see if they can find out whats going on with this truck
Griswalds
6.7L Power Stroke Diesel
12-17-2015 06:28 PM
