Every time I drive my 2000 SD extended cab on any kind of off road get lound banging sound like bed is loose. Check bed bolts they all seem to be tight. Checked cab bolts seem fine but not sure what I am looking for. Put long 2x4 between bed and frame and can't seem to get it to move. Any suggestions would be appreciated.
I have check the sway bar bushings and they seem fine. Might be a good idea to change anyway. Any suggestions as to what to use. Oem or Performance? Thanks for the reply
Energy Suspension makes a kit.Also check out the front page of this site for a detailed write up on replacing the bushing.
Thanks guys. Sway bar bushings were toast. Spare tire was to low. Cab mounting bolt loose but couldn't tighten. Need new bolts and bushings. Front shock bolts wore. Replaced the shocks and bolts. Had a hard time finding the bolts.
