Instrument cluster lens
Old 11-18-2008, 07:46 PM
COLMISS's Avatar
COLMISS
COLMISS is offline
Anybody got an instrument cluster lens I could buy? Mine is shattered so bad i can't read my gauges. Thanks!
Old 11-18-2008, 07:58 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Instrument Cluster Lenses are very comon in the Wrecking Yards too.
1973-1979 F-100/F-350
1978-1979 Bronco.
1975-1991 Econoline.
Old 11-19-2008, 10:30 PM
COLMISS's Avatar
COLMISS
COLMISS is offline
Not too many junkyards close by. I checked a few but no luck. One will turn up before too long tho. Thanks
Old 11-20-2008, 12:33 AM
alconk's Avatar
alconk
alconk is offline
You can buy a brand new one from LMC for $20
Old 11-20-2008, 05:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1973/79 F100/350 Instrument Cluster Lens & Cluster Backs / 1978/79 Bronco / 1975/91 E
D3TZ10880A .. Instrument Cluster Lens
REPRODUCED by Dennis Carpenter, who has 331 available: 704-786-8139
Caveat Emptor: Be very careful removing the old lens from the cluster.
Ford used an el cheapo composition material for the cluster back, and when you handle it, it doesn't take much for it to TURN TO DUST!
In 1981, Ford came out with a revamped cluster back which is all plastic, these are now obsolete, but have been reproduced by Carpenter.
E1PZ10848A .. Cluster Back-Use with Gauges / Fits: 1975/79 F100/350 / 1975/91 Econoline / 1978/79 Bronco
E1PZ10848B .. Cluster Back-Use with Idiot Lights / Fits: 1975/79 F100/350 / 1975/86 Econoline / 1978/79 Bronco
Old 11-20-2008, 07:40 AM
Behemoth's Avatar
Behemoth
Behemoth is offline
Numberdummy is NOT lying here, as I'll attest to that. The material Ford used for the cluster backing was fine when it was originally installed, but after 30 years or so of being subjected to wild temperature changes (lights, heater, cold, etc.) it becomes extremely brittle. I've taken a few of these clusters apart, and while some have been in acceptable condition, others I've been able to turn to dust just with my finger and thumb.
Before you install the new lens, you may want to inspect your cluster backing for deterioration. On the back there is a small flange that doesn't serve any purpose (probably part of the molding process), and if you can pinch that off with your fingers too easily, your cluster backing is probably about shot. Dennis Carpenter sells these items as well, not to mention the isolators, lenses, and other related items.
Myself, I'm basically building a new cluster from scratch from the parts available, but am making a couple mild alterations to it (nothing noticable). There's a place here locally that can install background LED's so as to make the guages more visible at night (which our trucks do have a problem with). Other than that, mine will be stock.
Anyway...just my $0.02
Old 11-21-2008, 08:14 PM
81-F-150-Explorer
The clusters from 1975 to 1979 were known to crumble as little as two years after the build date of the truck.
Why the cluster back was revamped in 1981 as numberdummy already stated.
The "E1PZ" cluster backs do not suffer from the crumbling as the earlier ones do, and can be found on lots of econolines built during and after 1981.
An easy swap if your cluster is falling to pieces.
Just switch the circut board and front gauge "cover" over to the new cluster back.
Make sure to match idiot lights with idiot lights, and gauges with gauges otherwise, like I said, a real simple swap.
Old 11-21-2008, 08:25 PM
kingford72's Avatar
kingford72
kingford72 is offline
I bought a repo lens 6 mounths ago from lmc and when it came it was in a dennis carpenter package so your still getting a good product and your buying it cheaper than you would than if you bought it from dennis carpenter go figure???
Tiggie
12-22-2016 11:50 AM
LOBO2
1978 - 1996 Big Bronco
10-22-2016 02:53 PM
f100today
07-19-2016 09:29 AM
dieseldodgeguy
12-15-2013 09:50 AM
yrc lugnut
12-05-2013 09:39 AM
Quick Reply: Instrument cluster lens
