Towing 5th wheel with
Old 11-09-2008, 01:39 PM
ranger56528's Avatar
ranger56528
ranger56528 is offline
a 08 F150 supercrewcab 4x4 with 5.4 and 3.55 rear.Is this possible to do with out damaging the tran or excessive rearend wear....
Iam looking at a 24-25ft 5th wheel so I can also tow a 14foot flat trailer with my atv's,Harley's and my Ranger dependind on what Iam going to do...I will be adding the ride rite airbag sytem to keep sag to a min....Also Iam a flatlander so towing up BIG hills is going to be minimal being how MN and ND aint got much for hills...
Iam trying to stay away from a pull behind toy hauler and dont need to spend alot on a 5th wheel being how Ive found a few for the 7-12 grnd range that fit the bill...
Old 11-09-2008, 02:30 PM
grafekie's Avatar
grafekie
grafekie is offline
What does the trailer weigh? Although many times and in many situations a half ton CAN do the job, a bigger truck would do it a lot easier and a lot safer. I tow a gooseneck horse trailer with my F150 and while I will defend to death its ABILITY to do the job, I much rather a larger truck for the added power and safety.
Old 11-09-2008, 03:19 PM
ranger56528
I know to keep curb weight under 8500 and my overall total is 11,000 and under being I have 17 tires and a 3.55 rearend,Ive looked at tow behinds that were in my range but then I dont have the trailer option and even a basic tow hauler is out of the ? due to there cost and the amount of use it would get and the wife really isn't interested in sleeping with wheelers right nxt to us in the same camper.....For me and the boys its not a issue but being how the wife's buying the camper I will do my best to keep her happy.
Old 11-09-2008, 07:49 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
As long as you have the tow package on the truck, a proper wt distribution hitch and trailer brake controller then you should be ok. Be sure to check the king pin wt if go with a 5th wheel because that gets added into the max load of the truck. Then keep in mind what you are allowed to tow. As long as you stay in those guidelines per your owners manual you can do it. Suggest you get the truck weighted empty so you know the true wt you are working with.
A F250 would be the better way to go if you are going to do this alot though.
Old 11-10-2008, 07:46 AM
hanklin's Avatar
hanklin
hanklin is offline
Ranger
Are you talking about double trailers behind a 150?
Hanklin
Old 11-10-2008, 10:07 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
Originally Posted by hanklin
Ranger
Hanklin
Yes it sounds like that is what he wants to do.
No way would I do that with F150 you will be asking way to much from the truck and its running gear.
We double tow all the time but I have a truck a little more suited for the job.
Denny
Old 11-10-2008, 12:44 PM
hanklin's Avatar
hanklin
hanklin is offline
Denny
thats what I was thinking too
My pal got rid of his 150 cause he had probs towing a 26` boat , picked up a dodge thru work(we`ll see how that goes)He also had hills and alot of around town driving
Hanklin
Old 11-10-2008, 01:21 PM
senix's Avatar
senix
senix is offline
I wasn't thinking he was gonna do that but now that I have re-read that it makes sense. He needs a 250.
Old 11-10-2008, 04:48 PM
ranger56528
I know Iam asking a lot out of a 150,maybe I should look into a used 250 for the heavier load but my main concern is a 150 towing a 24-25 foot 5th wheel...I really dont see what the dif would be over a 26 foot tow behind camper being how the weight would be over the axle with a 5th wheel rather then on the rear end with a tow behind.....and yes I do have the tow package...
Old 11-10-2008, 06:38 PM
wfof250v10's Avatar
wfof250v10
wfof250v10 is offline
I saw a guy towing a 30ft 5th with a F150, but didn't know what gears he had....but with 3.55....no way would I do that....not unless I had tranie insurance!!!
Old 11-10-2008, 09:10 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
What I was concerned about is the 14 ft trailer behind the 5th wheel. I think that you will find that 5vers are heavier than TT trailers.
Denny
Old 11-11-2008, 12:22 AM
Bill06FX4's Avatar
Bill06FX4
Bill06FX4 is offline
Am I reading this right? You want to tow a Ford Ranger on a 14' flatbed behind a 24-25 ft 5th wheel?
Ummm, no. A 6000 lb trailer behind a 7000+ lb trailer behind a half ton truck is not going to work...
Old 11-11-2008, 08:48 AM
grafekie's Avatar
grafekie
grafekie is offline
Yeah... talking a F350, not a 150
Old 11-11-2008, 10:39 AM
ranger56528
Denny
As in tounge weight versis 5th wheel pin weight.......
Bill06FX4
The trailer I would like to pull behind the 5th is a utility trailer that holds my 3 ATVs or one Polaris ranger and 2 Polaris 90cc sportsmans...
Ive found a 93 24ft 5th wheel that's selling for 7 grand and is in like new condition.
Old 11-11-2008, 10:51 AM
grafekie's Avatar
grafekie
grafekie is offline
Its just way too much trailer for a half ton to deal with. One, or the other would be possible... both is too much.
Quick Reply: Towing 5th wheel with
