Tranny problem(s) fixed
So Ive been posting over the last month or so about a few tranny problems I have been having. I had a really long shift delay from P to R or D and the TC would unlock anc lock under load. Well I fianly got around to dropping the pan this weekend and when the pan came down so did the filter. The advanced auto part filter I put in almost a year ago fell out of place and started sucking air. I replaced it with one from Ford and all my problems are fixed. The advanced one did not come with a new seal and I think that is the bigest problem with it becuase I had to reuse the old one. The Ford one does.
I still have a slight delay when going from P to R but I think it is pretty normal. The pressure does drop to almost 0 when it does this though. Durring that same time when the tranny was cold and I came up to a light, it felt like the TC was locking up and it would start to push through the brakes. It only did it when it was cold and only once or twice. This has not happened again sense the new filter.
Anyhow now I am looking into a VB from Racer X. A few questions are what all is in the VB when you get it from him? Does it have new valves or should I get new ones? What is a valve regulator? I don't know a whole lot about this part of my truck so anything you want to add would be helpfull to me. I want my truck to shift like a truck should and get rid of the slop. The RacerX VB seems like it will do what I want ot to do.
Thanks
John
Thanks
John
Was it a 2 wheel drive filter in the 4x4 pan?
https://www.ford-trucks.com/forums/7...-problems.html
Bill
Bill
Bill
Bill
Thanks, It is on the top of my short list. I cant belive the differance the filter made in the whole fell of the tranny.
2 more things though:
MADVAN told me the pressure at idle should be 50-65psi in P, N, D, 2 mine is at about 75-80psi. Any thoughts on what would cause this?
Second is the pressure drop when put into R, is that normal? It drops to 25 then goes up to about 130psi. MADVAN also said that the pressurre at idle in R should be 70-100psi so im high there too. Also when I am crusing and nail it the pressure can reach 200psi. I have a red brick Snap-on scanner If there is sometihing that it can help me with.
Thanks
John
Thanks
John
And here is something I could get from the forums about the VB and maybe helps you:
There are going to be some minor differences between each builder's valve body.
What you should expect from a custom valve body is firmer, quicker shifts more holding power on the clutches from additional fluid volume & pressure.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
You shouldnt feel too much of a difference without your chip in. in stock form the stock vb does a fine job. you would be able to tell a huge difference if you added the chip and then added the vb like a couple days later. you would feel the tc locking and all kinds of craziness going on in the higher hp modes<o></o>
<o> </o>
Stock power, you won't see much. Turn up the power and you need to do something... Im still waiting for my chip.
I bought and installed one VB from RacerX, and yes it came complete, removed the old one and install the new VB and thats it.
What you should expect from a custom valve body is firmer, quicker shifts more holding power on the clutches from additional fluid volume & pressure.fficeffice" /><O></O>
<O> </O>
You shouldnt feel too much of a difference without your chip in. in stock form the stock vb does a fine job. you would be able to tell a huge difference if you added the chip and then added the vb like a couple days later. you would feel the tc locking and all kinds of craziness going on in the higher hp modes<O></O>
<O> </O>
<O> </O>
<O> </O>
Well it worked very find, you feel the change inmediatly, I saw smoke with street race and more in extreme, and well also you feel the work that is making the VB, so in resume Im very pleasent with both the TW CHIP and VB RACERX.
. I hope you find out the same, good luck
