Crank pulley removal
Old 10-11-2008, 06:41 PM
Duke78's Avatar
Duke78
Duke78 is offline
Holy crap that bad boy is tight... Any tips on removing the crank pulley bolt would be great. Is it possible it's a left thread? The engine is a 300 L6. I have no impact wrench but i could possibly get one on loan, however i think it should be possible to loosen with a wrench.
Another question: Is it bad to wedge a wood block between the block and the crank to be able to torque the bolt?
Old 10-11-2008, 07:22 PM
chuck101st's Avatar
chuck101st
chuck101st is offline
Might be able to double wrench it. Take the box end of your wrench and put it on the bolt then take a bigger wrench and hook the box end of it over the open end of the first wrench. Or get a breaker bar. Usually use an impact though.
Old 10-11-2008, 08:21 PM
c4barnes's Avatar
c4barnes
c4barnes is offline
Should be fine, if you can fit it. Just the other day I used a huge screwdriver in front of the connecting rods and away from the inside of the cylinder wall. In retrospect I should have wrapped in a rag, and used an "impact wrench" in the form of beating the snot out of a 1/2" breaker bar with a mini sledge. After 17 years of MA road salt, nothing less would work.
I also read about threading bolts through the pulley and wedging them against the timing cover. But all that got me was a new timing cover after breaking the webbing on it, and the ill temperament that led to the above measure. Good luck.
Old 10-12-2008, 06:09 AM
srercrcr's Avatar
srercrcr
srercrcr is offline
You really should have a basic manual like a Haynes.
Old 10-12-2008, 08:57 AM
c4barnes's Avatar
c4barnes
c4barnes is offline
Haynes suggested a chain wrench, which in my case was a knife at a gunfight, but as a general point, yes indeed.
The following users liked this post:
Old 10-12-2008, 09:59 AM
Duke78's Avatar
Duke78
Duke78 is offline
I have a chilton, but they don't get into detail regarding the crank pulley removal or installation for that matter...
Old 10-12-2008, 11:15 AM
5.0Torx's Avatar
5.0Torx
5.0Torx is offline
i have a big metal bar that fits over my socket wrenches whenever i need the extra leverage to break loose a rusty bolt. Alot of the time my impact wont break stuff loose all by itself. When that happens i just break it loose with my 4 foot lever arm wrench and then finish it off with the impact.
Old 10-12-2008, 11:18 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
I have a 2 foot breaker bar that has yet to be defeated. Whether it actually loosens something or simply shears it off, it has never failed to get something to move.
Old 10-12-2008, 04:22 PM
5.0Torx's Avatar
5.0Torx
5.0Torx is offline
yeah the bar i slip over my socket wrench is the same. either its coming off the easy way or its coming off the hard way lol. If its a specialty bolt though i try to take it easy and not let it get too hot and keep it well lubed. For stupid **** though, or if im angry, *snap*!
Old 10-12-2008, 06:23 PM
kotzy's Avatar
kotzy
kotzy is offline
If you have the drive plate or flywheel on the crank I'd use a big screwdriver in the flywheel teeth to hold the crank. As far as a block of wood between the lower end of a connecting rod and the block, or even the journal and the block I just don't think you and a two or even three foot bar will hurt anything, unless your the lad I saw carry 5- 98 lb bags of cement. If thats the case I don't know and sure don't want to give you any bad advice. kotzy
Old 10-13-2008, 04:56 PM
Duke78's Avatar
Duke78
Duke78 is offline
Finally got the bolt. 4ft pipe on my 1/2" drive rachet, the bolt was a Nancy girl after that.
Anyway, i was pretty happy about it all, until i went to remove the pulley, that thing must be press fit on there also. Do i need a puller for this thing and since the pulley has a rubber ring between it and the hub i'm guessing a hook style puller will not work but rather the bolt on type i can attach to the threaded holes on the hub?
Do any of you know the bolt hole center spacing?
MyFX-4
2004 - 2008 F150
03-29-2010 12:20 AM
garymocwi
1983 - 2012 Ranger & B-Series
10-21-2008 09:03 AM
eallanboggs
1997-2006 Expedition & Navigator
04-17-2008 09:17 AM
aerocolorado
Aerostar
07-19-2007 04:23 PM
Dannym
12-20-2004 10:30 AM
Quick Reply: Crank pulley removal
