AC issue - Explorer
AC issue - Explorer
So we have this AC issue in our '05 Explorer.
I'm hoping its not a big deal to fix.
It does not blow like ice like it used to a few weeks ago, the passenger side blows cool air only (similar to as if the fan only were on) and the driver side has no cool what so ever, just air blowing on you.
I popped the hood last night and everything looks good, but i don't know much about AC workings. The AC motor (condenser?) turns on and off like it normally would, but seems to do it much more often, example: in 1 minute it clicked on and off about 6 times.
Whats up?
Does it need to be recharged? is the motor bad?
Thanks for the help!
Whats up?
if the clutch is cycling rapid then like y2k said it probably is low on freon. 134a dosnt evaperate so if it is low then you have a leak. You could get some freon with leak detecting dye in it at a parts store. Shoot that in it then with a black light find what is leaking. C/o that part then take it to someone who can pull a vacume and recharge the system to proper levels.
Keep in mind that you can't keep dumping freon in a low system without the proper equipment to evacuate and charge the system. Doing so can cause significant damage to the compressor and other components. I'm a firm believer in DIY repairs, but you need to know what you are doing and have the proper equipment for AC work.
Called around to a few different places and the average cost was about $190.
After the help from you guys and the techs on the phone i spoke with, i decided to go to the auto parts store and pick up a can of refrigerant.
Charged up the system and it is working perfectly.
Thanx again for the help!
Putting in a can of refridgerant is only putting a bandaid on the problem. The system was low because of a leak. the system operates on a specific amount of refridgerant measured in ounces. The only way to know if the proper amount of refridgerant is in the system is to evacuate the system with a vacuum pump and recharge it with the proper amount. The purpose of the evacuation is to remove moisture and air from the system before recharging. Doing this restores optimum system operation. Dan. Former tech certified in a/c repair.
I have a similar problem, posted in the AC forum about it. I have the same passenger vents cool, driver warm syndrome.
I had the system evacuated and recharged last spring for about 190$ at the dealer. Worked fine all summer, now does not work. They (in the spring) could not find a leak and I just looked with a light and glasses I borrowed and see no dye.
So Im still stumped. I'd add some r134 but the gauge that came with the can says level is normal.
Guess I'll take it back in in the spring...
muneeb
04-25-2016 07:45 AM
Thomas White
07-11-2015 01:25 PM
tonyrcl
1997-2006 Expedition & Navigator
07-26-2009 03:05 PM
