390 S Code Identification and Will It Fit In My 65 F100
I have the opportunity to buy a 390 from a 66 Fairline XL. The seller says it is an S Code motor. What I know is according to my Big Block Ford Engine book,
this should be a 390-4V and is a GT motor.
Three Questions:
1. What is a GT motor?
2. How do I know what to look for when I see the motor. How do I tell if it is it infact a 390 S Code.
3. I am planning on putting it into my 65 F100. It has a 352 that I want to take out, rebuild and store. The 390 is just for fun. The truck has an automatic transmission. Everything I have read tells me that a 390 is a direct bolt-in. Is this the same for a 390 car motor.....
Thanks for any help.......
Three Questions:
The 390 GT had higher compression, hotter cam, and "better intake", though by todays standards the "S" intake is not worth using. I have used this intake in the past, and it does not produce anywhere near the torque/hp at any engine speed of an Edelbrock performer RPM intake. I suggest going to web site: Woody's WebSite Main Intro., and look for his "390 build up the old way". His site lists all the details that went into the 390GT and offers several engine builds. Todays parts are far superior to building an engine the "old way". Camshafts, valve springs, cylinder heads, intake manifolds, electronic ignition, etc are today light years ahead of 1970.
BUT.... the 390GT engine would be a GREAT starting point for further improvments.
YOU could drill the vertical exhaust manifold pattern in the GT cylinder heads YOURSELF. Then your exhaust would bolt right up the GT heads. Hope this helps.
In my case, I have decided to temporarily replace the 352 with a 390, and would like to use a similar era engine rebuilt to the factory spec. Call me sentimental...
This seems like an engine that will give me more HP than the other 390's I have found. The big question is? How do I know if it is a 390GT?
Thanks for the great info.
I'm sorry I let that truck go as the 1984 F250 460, C-6 and 4.10 rearend (ouch) does 10 mpg on a good day but it never slows down regardless of what you are towing.
Great link for anyone doin' a 390 build-up! Thanks!
I was using a Holley List 1850, 600 CFM vacuum secondary carb, worked over by me. Dual stage power valve, heavier spring (just one step heavier) in the vacuum secondary, rejetted (primary and secondary) and keeping the speed down to under 58 mph so the revs stayed down below 2800, as the secondaries opened under load at 3000 rpm.
I might look into your setup.
John
1966_F100
03-22-2010 07:31 AM
taylorjgreen
21
09-01-2008 09:32 PM
390man
03-10-2003 06:32 AM
