Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-22-2008, 04:46 PM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
Exclamation Disk Brakes and Power Steering on 2wd
Another article by Jared (Ford_Six)
Power Steering & Disk Brakes 2wd 65-72 .: Articles
__________________
Adrian
FTE Guidelines
  #2 (permalink)
Old 09-24-2008, 09:50 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
interesting article. i have power steering, manual drum brakes, and shot kingpins. so i can just get a donor truck and yank off the whole front end and not even have to mess with kingpins? and i get power disc brakes? sweet. but will my tie rod and drag link fit on it?
__________________
69 f100 360 c6
timing chain & gears, hooker headers, perf dist hei ignition, ed carb intake cam lifters, pioneer deck w ipod tuner 5000 songs, ac w new exp valve compressor condenser hoses and fresh virgin r12, new steering, new suspension, new tires, dynamat sound insulation on the firewall. did it all myslef
  #3 (permalink)
Old 09-25-2008, 05:50 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE.
I'm glad he did that, because that original article was full of bad information. IMHO
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 09-25-2008, 11:59 PM
im really thinking about doing this conversion. my drums have always served me just fine for daily driving, but for towing stuff they just dont cut it.
__________________
69 f100 360 c6
  #5 (permalink)
Old 09-26-2008, 12:40 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
You will need to make some other changes for a manual to power swap, something about the pedal pivoting differently, and of course adding a booster.
You will need to use the tie rod and drag link for the truck you get the I-beams from, as they are different lengths for different setups. I ran into this first hand using the wrong tie rod off my old truck before I did this swap, and wore out a nearly new set of tires in about 400miles.
The braking difference is huge, this thing pulls down quick now. As an example, towing a trailer load of scrap, crossed the scales at 9680lbs and it slowed quicker than it did towing the empty trailer with the 12x2 drums. Also much less fade, more predictable engagement, and best of all, no guessing which side it was going to pull to this time.
It took me about two days altogether, but it was time well spent.
I do know that the writing style isn't that great, this is pretty much my first shot at this, so if anybody needs anything explained or worded differently, let me know.
__________________
Quote:
Originally Posted by ScottInTexas View Post
Beware the politician who says he is doing something for you. It usually means he is doing something to you and it will probably be unpleasant.
FTE Guidelines
  #6 (permalink)
Old 09-26-2008, 10:59 AM
DarkWolf40's Avatar
DarkWolf40 DarkWolf40 is offline
DarkWolf40 is starting off with a positive reputation.
I'm doing this right now but I got all the parts from 3 different trucks. I've also refreshed everything as I went so new king pins seems like the right thing to me since everything is out on the ground. I did have trouble finding someone who knows how to do the king pins correctly, they must be reamed, not honed to fit correctly. I also degreased everything and panted everything with POR15 so this has taken longer than a couple days. Also, I did not get a cooler, in fact I did not see one in the 3 wrecks I pulled parts off of, they were a 74, a 75 and a 77. Why would ya need a cooler and will I be OK without one? Can't say I've ever seen a power steering cooler before.
  #7 (permalink)
Old 09-26-2008, 11:39 AM
Ford_Six's Avatar
The cooler I used is basically a serpentine hard line that bolts to the frame below the pump, and cools the fluid heading back to the pump. Any hydraulic fluid under pressure will generate heat, and the pumps and boxes are very sensitive to overly hot fluid. Over the years Ford really cut back on the cooler, and that is the cause of failure for so many pumps in the 80s, those only had a small loop on the main crossmember under the engine. This would get caked with oil, and all nicely insulated so the fluid would be hot going back to the pump. The cooler these trucks should have looks like a mini radiator and goes on one of the pump bolts, right in the flow of air from the fan.
__________________
FTE Guidelines
  #8 (permalink)
Old 12-06-2008, 08:26 PM
Nathan-So. Illinois Nathan-So. Illinois is offline
Nathan-So. Illinois is starting off with a positive reputation.
Help needed to find 1967 4x4 hard to find parts
I was reading your article on power steering. I'm close to a complete restoration and needing power steering assist cylinder and 67' grille. Any ideas or input would be great.Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
