Big problem with 67' f100
Old Dec 5, 2008 | 09:33 AM
rastafob's Avatar
rastafob
hello
I have a 1967 f100 with a 390 was running good till now,
once i get it started it runs good but when im in drive and step on the brake it shuts down its like the fuel line cuts off. i have to put it in nutreal to come to a complete stop. i changed the plugs distributer cap and roater and used a fuel system cleaner and still no luck. i think something might be clogged.
any help would be greatly appreciated!
Old Dec 5, 2008 | 09:40 AM
Dave Severson's Avatar
Dave Severson
Might want to replace the fuel filter and check your fuel pressure...then also check the idle speed in drive and readjust the mixture screws--a vacuum gauge works very good to adjust the idle mixture.... what is the dwell on your points? Wondering if they might be a bit tight....
Old Dec 5, 2008 | 10:52 AM
Freightrain's Avatar
Freightrain
Just stepping on the brake causes it to stall? Or only when coming to a stop?
Does it have power brakes? Could be a faulty brake booster causing a major vacuum leak when you step on brakes.
Still stock carb?
Old Dec 6, 2008 | 03:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When you step on the gas from a dead stop, does the truck bog down, and sputter like it wants to die?
When you punch it at speed, does the same thing occur?
If so...this is a typical 2V carb problem.
Replace the accelerator pump diaphram and check valve.
Problem solved.
Originally Posted by freightrain
Could be a faulty brake booster causing a major vacuum leak when you step on the brakes.
I'd be inclined to make sure the following two parts were OK before replacing the booster.
C4DZ2365A .. P/B Booster Check Valve / Fits: 1965/67 F100/250 / 1964/68 Falcon / 1965/68 Mustang.
C9AZ2B176B .. Check Valve Rubber Grommet.
The grommet fits into the booster, the valve fits into it.
The grommet over the years hardens up due to engine heat and cracks.
When that occurs, you now have a vacuum leak at the booster.
Old Dec 6, 2008 | 07:45 AM
Freightrain
Good idea Bill. That's the problem with internet, I don't always type everything I'm thinking. I tend to leave out the little things I would do, like wiggle hose, check the fittings, etc.
Old Dec 6, 2008 | 10:23 PM
Danger_Dave's Avatar
Danger_Dave
how bout take your carburetor off the truck, set it on a workbench, and take it apart and thoroughly clean it out, then dial in the mixture, jet sizes, etc, and work on getting that timing where it needs to be.
JoeHarbourJets
Mar 12, 2012 10:59 AM
JoeHarbourJets
May 9, 2011 08:05 PM
abreiholz
Mar 17, 2011 01:07 PM
holt12
Jun 28, 2005 09:10 AM
Merlin68F-100
Feb 25, 2005 07:49 PM
