boost guage.
Old 09-08-2008, 03:47 PM
Core250PSD's Avatar
Core250PSD
Core250PSD is offline
boost guage.
So I have my pyro, and trans temp guages installed, but where do I tap in for the tee that comes with the boost guage? If someone could show me a pick with the exact location it would be a great help. Thanks in advance
Old 09-08-2008, 03:54 PM
884x4broncoII's Avatar
884x4broncoII
884x4broncoII is offline
most people t-into the map sensor line
Old 09-08-2008, 04:08 PM
ron86toy's Avatar
ron86toy
ron86toy is offline
x2 its the line just above the pass valve cover that runs to the firewall...I think I have a pic...will check and post back
Old 09-08-2008, 04:24 PM
ron86toy's Avatar
ron86toy
ron86toy is offline
not my pic but it shows where it needs to be
MAP SENSOR pictures from trucks photos on webshots
Old 09-08-2008, 09:11 PM
Core250PSD's Avatar
Core250PSD
ok, so I teed into the map sensor line. Does it matter whether it's closer to the vavle cover, or near the firewall? I have it closer to the firewall cause it allowed for a neater install, but it seems slow on the guage when I get into the throttle...seems to be delayed. Highest boost reading so far is 15psi, does that sound right?
Old 09-08-2008, 10:18 PM
ron86toy's Avatar
ron86toy
ron86toy is offline
That sounds about right...My max is 19-20...my only difference in mods from you is a 6637 and a 6pos TW chip.
Old 09-09-2008, 06:40 AM
Core250PSD's Avatar
Core250PSD
ok I drove around for a bit last night and I got 600* egt cruising 60 on the highway, 300* at idle, and 800* on a hard accelleration. trans temp only ever got up to 115*
Old 09-09-2008, 07:18 AM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Sounds like you are in. The #'s are consistent with others with your mods. I used to get 25 psi but all trucks are different as you will see.
ramirez7589
04-06-2015 10:33 AM
LiftedBlackHD
03-29-2015 09:26 PM
94diF350
10-19-2011 05:54 AM
JHoffman93
01-16-2010 09:23 PM
rtazz17
10-17-2009 08:15 PM
Quick Reply: boost guage.
