2005 and Newer F-150 Starters
Old 08-28-2008, 09:15 PM
Fordication's Avatar
Fordication
Fordication is offline
Well my 2006 Ford Screw lost its starter at 37K miles. This is a Lariat with everything and up till today no problems. In fact this is my 4th Ford Lariat since 1996 and the first to have a problem. It was not covered under warranty and set me back 400 bucks. I am curious, has anyone had problems with their F-150 starters on this series of trucks? Thanks
Old 08-28-2008, 10:24 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
wait a minute....shouldn't that be covered under the powertrain 5 year 50k warranty......I'd call ford.... Even if it wasn't, i'd still call ford.... my buddy just got gm to replace the bcm on his malibu 20k miles out of warranty.....you should be able to get a starter at 1k out....
But really...that should be a 5/50 warranty issue
Old 08-28-2008, 10:31 PM
Fordication
That is what I am looking at now. I think they should cover it as well but the Ford folks said that is not power train. How the hell do you start the power train without a starter? I am clueless but what do you expect.
Old 08-28-2008, 10:41 PM
99whiteford's Avatar
99whiteford
99whiteford is offline
I can understand it being out of warranty,because truck is over three years old.Also in some cases, mileage doesnt truly reflect a starters usage.i have a customer that had replaced the one on his Yo,three times when the vehicle has just under 60,000 miles.his line of work makes him start his vehilce around 30-35 times a day.
The thing I dont understand is the Four hundred Dollars.I Rebuild them for $89.95.and most of the Auto parts around here sell them retail for $139.95--$179.95.
Even with hourly shop rates like they are know I cannot imagine over one hour labor for the installation.
Old 08-29-2008, 01:16 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
he may not have the 5 yr warranty. my 06 has the 3yr/36k warranty. sucks...and I can't figure out why some 06's got the 5yr, while I got the 3yr
I agree, this should be a warranty item (if still under warranty)...also, what did they charge you? I would expect $200.00 to $250.00 tops (1 hr labor, $100-150 for the part)
Old 08-29-2008, 09:15 PM
efx4's Avatar
efx4
efx4 is offline
I agree that 400.00 is way too much. You are only 1000 miles out of warranty, hopefully Ford will change their mind and pay for the repair, sometimes that happens. Other than the bumper to bumper warranty, the powertrain warranty usually covers parts lubricated by motor oil.
Old 09-01-2008, 06:36 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I had to have the starter replaced on my '05 at 500 miles because of a bad solenoid, and if I remember right the repair sheet the dealer gave me for my records said $700 total, I was sure glad it was covered under warranty.
Old 09-01-2008, 06:42 PM
Ford Fx4's Avatar
Ford Fx4
Ford Fx4 is offline
Yep, Ford for what ever reason did not start the 5yr/60k warranty until the middle of July 06. Everyone that bought before that got the 3yr/36k while everyone after got the 5yr/60k warranty with a $100.00 deductible after the first 3yr/36k. Then starting on the 07's they went away with the $100.00 deductible.
I was lucky as I bought mine in August 06 and got the 5yr/60k powertrain warranty
Old 09-01-2008, 10:53 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Well I think 400.00 is a joke for a rebuilt starter. The ford list price is only 186.00 + 40.00core. The starter is only about 150.00 retail at a store and can be installed in under 10 mins. These starters only have 3 bolts and 2 electrical connections.
While we find your parts, please enter your ZIP Code at PartsAmerica.com
Old 09-02-2008, 03:18 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
build 7/2006
bought 10/2006
3yr/36k warranty and nothing else...is there anything online where I can check my warranty? I specifically asked the repair department back in Spring 2007 and they said I only had the 3/36 and nothing else
I bought the premium ESP just in case
Old 09-02-2008, 06:29 PM
ford390gashog
Tylus,
Its on the ford website. Any 2006 model vehicle bought after July 14th 2006 came with a 5/60k powertrain warranty.
Old 09-02-2008, 11:02 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
the Ford dealership doesn't say that. according to them, I have a 3yr/36k only....and the 5/60k doesn't apply
I guess I need to ask another dealership
