won`t charge
won`t charge
Have you tested the batteries? If a battery is not accepting a charge or has an internal short, the whole system may have a low volt reading. Are you using a voltmeter or the dash meter? if you are using the dash one, get a voltmeter and double check it. It might be lying to you.
88 F-150 4X4 w/5.0 EFI 5 spd
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4
won`t charge
Thanks for replying. Iwas checking everything with my voltmeter.Itook my battery back that I had just bought in December and the computer said it was goodbut low,so they put it on trickle charge until tomorrow night.So I`ll let you know tomorrow night how I make out
Thanks again.
Thanks again.
biggdirty7.3
01-10-2017 10:17 AM
