Modular V10 (6.8l)
IAT Sensor
Old 08-25-2008, 06:33 PM
i eat hybrids's Avatar
i eat hybrids
i eat hybrids is offline
IAT Sensor
Do you guys know where it is at on the v-10? I check eng light is on and i took it up to autozone and they said it was a IAT sensor or MAF sensor.
Old 08-25-2008, 06:51 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Post the exact fault code.
The idiots at autozone aren't mechanics.
Steve
Old 08-25-2008, 07:21 PM
i eat hybrids
The codes are P0113 (IAT) and the other code is P0102 (MAF or MAP). Thats what the reciet says that autozone printed.
Old 08-26-2008, 07:27 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
What year ?
I recently installed a CAI kit on my V10 - there was a provision for a seperate IAT, but on my V10, there isn't one.
I believe the intake air temp is done with the MAF on my '01.
But if there's a seperate IAT for your year, it would be in the air box, or just after it in the intake tube.
That code you posted means "intake temp high" - meaning the sensor isn't necessarily bad (code would say "circuit" in it), just that the air intake temp is reading too high.
Might have a dirty MAF if it's reading it off the MAF.
Old 08-26-2008, 09:03 AM
i eat hybrids
I just cleaned the MAF last week with MAF cleaner. I got rid of the stock cone and put an after market one on their. Its off my buddies 04 mustang, he gave it to me because he got a S/C kit for it and the kit came with a intake. So anyways once we installed the kit, we realized that he needed to use the MAF that was on my truck (the one that he gave me with the cone) so i had to take it off. I drove around without a MAF for 3 days until i put the stock one back on. The stock one is on now but with the aftermarket cone still on their. After i hooked up the stock MAF, i found that it was still throwing a CEL. So i took it up to Autozone and the codes that i listed are what they found.
BTW, its a 01
Old 08-26-2008, 09:18 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
With all that mucking around, reset the PCM and drive it for a few days and see if it comes back.
Old 08-26-2008, 11:23 AM
i eat hybrids
Ok. Thanks ill try that and see what happens. Ill let you guys kno in a day or to.
Old 08-26-2008, 07:51 PM
Skoda's Avatar
Skoda
Skoda is offline
Founds this on the site, hope it helps narrow down the problems for yea
"The P0113 code means your Intake Air Temperature (IAT) sensor is sending a voltage signal back to the PCM that is too high (over 4.6 volts)
As noted, the IAT is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases, and increases as the temperature decreases, (proportionally in each case). This varying resistance affects the voltage drop across the sensor terminals, which allows for a voltage signal to be sent back to the PCM corresponding to temperature.
The voltage signal that is sent back to the PCM is equal to the Reference Voltage (VRef, 5 volts) minus the aforementioned voltage drop across the fixed resistor. That is why an open in the circuit between the PCM and the IAT will result in "too high" voltage signal at the PCM (i.e., 5 volts). In addition, corrosion in the circuit would tend to add resistance and hence result in higher-than-normal voltage at the PCM because of the signal being based on voltage drop.
In any case, if the circuit checks out OK, then it's either the IAT sensor at fault, or the PCM."
Old 08-28-2008, 03:53 PM
i eat hybrids
I didnt have time to unhook my battery cables over the past couple days (busy with work and FF school) So i just let the check engine light stay on. On the way to the FF acadmey today, i got into my truck and turned it on and the check engine light was off . Its been off ever since i got into the car this mornin. Thanks for the helpful tips!
Old 12-21-2014, 04:01 PM
trouble1's Avatar
trouble1
trouble1 is offline
Help!! My air intake temp sensor went out on my 2006 ford f250 power stroke turbo 6.0 where is it located and how do I change it?
Old 12-21-2014, 07:07 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Well first you go to the right section search the FAQs/ stickies and then if you can't figure it out start your own thread.
How do you end up locating a thread from 6 years ago in the wrong section expecting an answer.
Old 02-25-2018, 05:23 PM
lannondiesel's Avatar
lannondiesel
lannondiesel is offline
I have a 1997 E350 and I got the p0113 code today, the sensor was disconnected, it was just outside the air filter housing on the intake tubing
hutch246
17
01-22-2017 12:25 PM
Greg Price
12-31-2015 09:10 AM
ponyxprs
2004 - 2008 F150
09-13-2012 06:40 PM
mechelement
15
09-05-2009 08:18 AM
Peter94
1983 - 2012 Ranger & B-Series
08-29-2003 10:35 AM
Quick Reply: IAT Sensor
