Unsuccessful in SIPHON attempt
Old 08-25-2008, 02:56 PM
neilc88's Avatar
neilc88
neilc88 is offline
Ok,
I have a siphon pump and tried to siphon gas from the X to the wife's van. The siphon hose went down ~2' then seemed to hit a stop. I couldn't get the hose to go down the the gas level.
The reason I'm trying to do this is because Giant Eagle give fuel perks. I can get a free fill-up (up to 30 gallons). I want to fill the X when its low and give some extra gas to the wife's van.
Any tricks in getting the hose in far enough?
Neil
Old 08-25-2008, 05:22 PM
1's Avatar
1 is offline
The OBDII cas have some sort of flap or something like that that will not allow a car to be siphoned. I was told this by a former GM, now BMW tech. Most cars got these in the late 90's apparently. He said he has tried like crazy to get passed em when he had to do fuel pumps on cars with full tanks of fuel but was never able to get around it.
Old 08-25-2008, 10:13 PM
Mr. Obvious's Avatar
Mr. Obvious
Mr. Obvious is offline
I didn't have any problems getting gas out of my 99 Caddy when the gas station filled me up with sludge/water.
Old 08-25-2008, 10:19 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
While pushing on the hose, rotate it at the same time.
I recently had the tank and filler neck out of my '01 SD and there was nothing in there to stop a hose from going all the way in.
You could be hitting a lip of some type as you enter the tank.
Old 08-26-2008, 12:30 AM
FordxFour's Avatar
FordxFour
FordxFour is offline
I Just siphoned 5gal. out of my X about a week ago to put in the riding mower. As kwewat says, rotate hose while pushing. I just didn't feel like riding to the store and I had a full tank in the X.
Old 08-26-2008, 06:43 AM
neilc88's Avatar
neilc88
neilc88 is offline
Any idea what size hose and how long it needs to be? I did try to rotate but it seemed to be hitting a stop.
Old 08-26-2008, 09:29 AM
FordxFour's Avatar
FordxFour
I used a piece of 1/2" air line.
Old 08-26-2008, 08:27 PM
kev03's Avatar
kev03
kev03 is offline
When we get the free fuel perks and get free gas. We use gas cans. We fill one car up and then put the rest of the 30 gal in four 5 gal cans.
Old 02-12-2009, 06:31 PM
jspringator's Avatar
jspringator
jspringator is offline
Does anyone know how long the hose should be?
I want to be able to get gas to run my generator when the power goes out again, or when on vacation.
Old 02-12-2009, 08:40 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
My brother and I made an extremely unsuccessful attempt at siphoning out of his '05 F250 Diesel. Had the same issue as the OP, and the mechanic said that it was made that way to prevent the gas from being siphoned.
We tried rotating, shoving, tickling, pleading, bribing, and shouting... but the dang hose never went in.
Old 02-13-2009, 07:37 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Now that's funny, I don't acre who you are!
Old 02-13-2009, 12:38 PM
Wopstar's Avatar
Wopstar
Wopstar is offline
There is usually a check ball on the inlet of the fuel tank that will not allow you to siphon it. No way to bypass it unless you are going to pull the whole inlet hose off.
Old 02-13-2009, 01:14 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I never saw any check ball in any fuel filler neck that I've ever seen, and that's mid 80's Fords and earlier, and even my 2001 Superduty gasser.
There's a FLAP in the filler neck, but a hose can easily go past that.
I recently had the tank and filler neck out of my SD, and the only thing stopping a hose from getting in there was the angle of the neck, and the flange where the filler hose meets the tank. There's a ridge inside, so it's kinda hard to get the hose past it.
I've put 3/8", and even stuff that looks like garden hose into almost every gas tank I've ever owned, at one point or another.
Now, there HAVE been these coil spring setups inserted in some filler necks, but they were usually aftermarket.
Not sure about other manufacturers like Chevy/Dodge/etc, but all my Fords never had anything stopping it from being siphoned. Just a ridge somewhere, that's hard to get past.
Old 02-13-2009, 07:51 PM
Immortal_Ben
Toreador_Diesel <!-- BEGIN TEMPLATE: bbcode_quote --> Quote:
<table border="0" cellpadding="6" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset ;"> Originally Posted by Immortal_Ben
</td> </tr> </tbody></table>
<!-- END TEMPLATE: bbcode_quote -->Now that's funny, I don't acre who you are!
......stoopid hose
Old 02-13-2009, 09:15 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
X_Hemi_Guy is offline
Marty,
This wasn't your last ride to the store on the mower by any chance was it?... Lawnmower Taser Arrest
Sorry when I read your post about the riding mower...this clip came to mind!
Joe
JMZ1970
05-15-2017 10:05 AM
76f350spercamprspeal
03-06-2017 10:47 AM
lameousername
09-06-2015 04:17 PM
transjam2001
19
04-04-2015 02:29 PM
Knothole
1999 to 2016 Super Duty
07-07-2012 11:58 AM
Quick Reply: Unsuccessful in SIPHON attempt
