Glycerol.............
Old 08-22-2008, 03:03 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Another use for glycerol just popped up. Researcher converts biodiesel-waste glycerol into omega-3 fatty acids
How many more will be found???
Old 08-22-2008, 05:11 PM
empiretc's Avatar
empiretc
empiretc is offline
i enjoy using it as a replacement for roundup (i buy the concentration ingredient from wilber-ellis, not the walmart stuff). as long as the price of roundup stays way up there, i will keep using it as such.
Old 08-22-2008, 05:26 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
It works great on a dusty driveway also. it also seems to either kill or cause to relocate fire ants
Old 08-22-2008, 06:23 PM
empiretc's Avatar
empiretc
empiretc is offline
yes! i found that out too.
i use NaOH, BTW.
Old 08-22-2008, 09:42 PM
empiretc's Avatar
empiretc
empiretc is offline
Don, what is the easiest way to accelerate the process of settling the glycerol out of the bio?
Old 08-22-2008, 09:56 PM
fabmandelux
That's something I'm working on now I think electrostatic separation is the way to go. I've done it in my lab, but I'm working on a continuous system. I'm still looking for a clear plastic tube about 4" X 4-6' long. Got one laying around you can send me???
If I can get this to work, I think you could run the "mix" right from the reactor straight into the electrostatic separator, then into separate tanks.
Soon as I get moved I'll try and get a test set up made................
Old 08-22-2008, 10:03 PM
empiretc's Avatar
empiretc
empiretc is offline
good deal! look forward to your findings!
Old 08-22-2008, 10:42 PM
bradyracing's Avatar
bradyracing
bradyracing is offline
Clear PVC Pipe and Fittings - Alsco Industrial Products Has the clear pipe you need. We use 3/4, 1, 1 1/2, and 2 inch. We use sch 80 and it holds up better than any other sch 80 you would normally buy. I don't recomend any PVC in bio production but this stuff is great. They make it up to ten in diameter I beleive.
Old 08-22-2008, 11:23 PM
fabmandelux
Wow! $189 for 10' of 4" scd 40 pipe. I only need 4', and they only sell in 10' lengths............I'm going to have to think about that...............
Old 08-26-2008, 08:53 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
make 2 if it works?
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-02-2009 07:05 PM
blkbeast
08-15-2008 07:16 AM
Tom D
04-08-2008 07:44 PM
Gun-Driver
01-26-2007 09:22 AM
fordman 460
06-19-2006 11:11 AM
Quick Reply: Glycerol.............
