caliper rubbing wheel?
I ordered some aftermarket wheels for my truck and had the front two put on and tried to move my truck but it didn't move very easily. I took the wheel off and noticed marks on the caliper, the company I bought the wheels from said that ford had a few different companies make the calipers and not all calipers are the same. He said to grind a little bit off the calipers. Wasn't sure if anyone else ran in to this problem or if grinding on the caliper was a good idea.
it was really the rotor that was improved. something about the materials being wrong. but the fix involved a slightly different style caliper as well
still got your stock rims? I believe they are 4.5" OEM backspacing. might want to check your new rims
as for the calipers, I wouldn't grind them. give a parts store a quick look and measure what they sell for a 2006 F-150 vs what is installed on your truck.
how much clearance do you need to keep from rubbing? grinding scares me, but if you only need 1/8" or so, then that probably would be safe if the caliper has enough metal to spare
It sounds like there is minimal contact between the caliper and the wheel. As the OP said, he could turn the wheel. Can you post a pic to show where the contact is, on the caliper? You might want to search something like Baer brakes to see if they list any info regarding recommended caliper to wheel clearance. While you can grind to make some room, you're going to be running much tighter then these parts are designed to be. And remember when you apply your brakes, especially if you're working them hard, you're going to induce a fairly heafty amount of heat into the caliper and it will expand. Will it be enough to contact the wheel, I can't say, but you will be more prone to issues with road debris getting caught between the wheel and the caliper.
Your wheel dealer really isn't interested in helping you out with the just grind the caliper fix.
Like Tylus is suggesting, check out the newer caliper design. But check with your friendly Ford parts guy to see if they are interchangeable. Maybe that will solve this issue.
