BioDiesel and 7.3L vs new 6.4L.
Old 08-17-2008, 06:15 PM
jle70's Avatar
jle70
jle70 is offline
I was reading in these forums that anything greater than B5 may cause problems with the 6.4, but what about the 7.3? I have been using anywhere from B5-B11.
Old 08-17-2008, 06:47 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
I am sure 7.3s are fine on B100. I know people who run B100 exclusively.
Old 08-17-2008, 07:52 PM
barebackjake's Avatar
barebackjake
barebackjake is offline
i run 100 in my truck most of the time with no problems, may be hard on some factory fuel lines i havent had any leaks but i dont have a factory fuel system
Old 08-17-2008, 08:23 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Mine loves the B100 homebrew! 300 gallons so far.
Old 08-18-2008, 11:28 PM
sbxworship's Avatar
sbxworship
sbxworship is offline
once you've run b100 for about 6 months, your stock rubber fuel lines will turn to goo. Check out The Grease Works Online Store for a replacement kit.
btw - no, I don't get a commission from these guys, I've just installed their kit on three 97 psd's... I've been making/using biodiesel for about three years now. These trucks are great for WVO, too, if that interests you.
Old 08-19-2008, 02:36 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Which fuel lines? The ones in the valley? going up to the Engine off the frame?
Old 08-19-2008, 05:57 PM
884x4broncoII's Avatar
884x4broncoII
884x4broncoII is offline
i was under the impression that 96and up already had the synthetic fuel lines and that bio did not hurt them. mabey someone here can prove or disprove that.
Old 08-19-2008, 10:49 PM
sbxworship's Avatar
sbxworship
Both my first 97 psd and my father-in-law's went gooey on all the rubber lines after about 6 months or so. First it drew air, and then it leaked fuel, which got all over my wire harnesses...
The ones in the valley (Three on the pump, and one vertical beside the bowl), and the high pressure lines in front of the bowl. My first truck also killed the diaphragm on a few fuel pumps... What a mess...
I outfitted my next one with the viton lines right from the start. Live and learn! All good so far, and it's been about 6 months...
Old 08-20-2008, 04:52 AM
884x4broncoII
i run b10 quite a bit as its available locally at a truck stop in town will b10 be enough to do anything to the fuel lines?
Old 08-20-2008, 06:05 AM
sbxworship's Avatar
sbxworship
you should be okay up to b20, i think...
sledhead999
15
12-25-2012 01:19 PM
StanleyZ
6.4L Power Stroke Diesel
40
05-19-2012 06:57 PM
Mike821
01-06-2010 08:30 PM
high ho silver
1999 to 2016 Super Duty
23
02-08-2008 03:13 PM
Craig64
54
01-06-2008 11:51 PM
Quick Reply: BioDiesel and 7.3L vs new 6.4L.
