Super Duty running light issue
All of the running lamps are in parallel off one fuse. If only one light is out, then the problem is with that lamp fixture, its ground, or its wiring back to the splice.
Check the lamp socket for corrosion, check the ground, and check continuity of the power feed back to the adjacent light. One of those circuits is open (unless you installed a defective or bad bulb or it's installed wrong).
Shaynekatrina
General Automotive Discussion
01-16-2015 11:05 PM
mdellatore
Electrical Systems/Wiring
12-07-2012 11:42 AM
