Drilling holes in Head Lights / Tail Lights Help
Do any of you guys know how to drill a 1 inch sized hole is your headlights and tail lights, without cracking the reflective thin plastic? I did one headlight with a not so good outcome. Do you recommend a Uni-Bit or a 3/4 in drill bit since thats the biggest they go, according to Home Depot. I am really not sure what to do know, I don't want to destroy any more lights.
Angelo Cosma
Angelo Cosma
i would think that any drill bit would work.... but start small, and go SLOW !!! let the drill do the cutting, and dont use much force behind the drill. i wouldnt recommend a uni-bit since you generally have to press rather hard to get them started. if you do use a hole saw, then get one with fine teeth, and still go slow.
im not sure what the home depot guy(or gal) was talking about, but you can defnately get bits larger than 3/4"..... maybe it was meant for your particular size drill thats the largest you could fit..... but if that was the case, then you can get the special bits that have a smaller shank to fit inside the smaller drill heads.
This is the way I did my nephew's just last week for his strobes. Go to a plumbing or electrical supply and get a fine holesaw bit though. The holesaw bits at the big box stores are too aggressive and will destroy the lenses.
So you guys still think the strobes look bad, tell me what you think?
YouTube - http://www.youtube.com/watch?v=jtTDqEqKlZA
Angelo Cosma
Angelo Cosma
RUN4CVR
13
07-22-2014 08:34 PM
