91 f-350 wont start???
I had the same problem with my 96 460. I would get gas and would turn over but wouldn't start. I first thought is was the fuel pumps So I took the fuel filter off and turned the key on to see if each pump was pushing out fuel. They were. There's a much better and safer way. ( Check fuel pressure at the rails with a gauge.) Next I checked the spark. I ended up replacing the ignition module and thought I had it fixed but the problem came back a few minutes later. It turned out to be a bad ignition coil.
galeggs
10-06-2013 07:51 PM
fordfan1979
1983 - 2012 Ranger & B-Series
16
05-09-2006 08:36 PM
