Fuel delivery issues
Old Nov 7, 2004 | 08:11 AM
tampabandit's Avatar
tampabandit
ok guys i have a 91 f-150 ext cab and the fuel pump in the front tank runs constantly but it is now sounding like it is starving for gas..it wont start without a spray of starting fluid in the throttle body and it will idle but as soon as i hit the gas it stutters...if i try to restart the truck it wont unless i hit it again with the starting fluid. i have dropped the tank and it seemed to be pumping fuel thru the filter and it has pressure at what looks like a valve stem on the fuel rail and i have replaced the what i believe is the fuel pressure regulator any ideas on this would be grateful im starting to lose faith in ford..thanx for any help tim
Old Nov 7, 2004 | 08:55 AM
MustangGT221's Avatar
MustangGT221
To all users, please make subject titles accurately reflect the subject matter
Old Nov 10, 2004 | 02:26 PM
mike L's Avatar
mike L
Wont run fuel problem?
Do you have any trouble codes? see www.fordfuelinjection.com I'm having the same problem. Do you have fuel in your vacuum hose on top the fuel pressure regulator?
mike
Old Nov 11, 2004 | 05:40 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check your fuel pressure when switched to the front tank and when switched to the rear tank. The front pump runs even if you switch to the rear?
Alm200
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 23, 2015 05:20 PM
wbhertel
Jun 27, 2012 05:04 PM
Justawondering
Apr 14, 2012 07:46 PM
tsop01
Apr 19, 2011 08:42 PM
buckeyebrad
13
Jan 20, 2010 11:22 AM
