2003 4.6l v8 - stalling at low idle or coast
74,000 miles and just started stalling after vehicle warms up. Will even get a surge. Can keep running by increased gas. Just recharged AC myself??? Could that have caused. Also makes noise like metal hitting on empty can.
Thought could be egr valve or fuel fillter? Where do i start? Thanks
I started having a similar problem with my 2000 4.0L OHV about a month ago. The body on the crankshaft position sensor had gotten cracked and water would get in there every time I hit a puddle or went through the carwash. I can't remember which code it woudl throw when that happened, but I will try to look it up. This is a $20 part and about 30 minutes of cussing to fix.
I also had a similar problem with my 1997 F150 4.6L. Turned out that the torque converter lockup solenoid had gone bad. As I slowed down, the engine would start to bog and finally die just as I can to a stop. I could keep it running by revving the engine. In this case, I wasn't throwing any codes at all. If your check engine light isn't on, you might consider this. The local transmission shop fixed it for about $200 and I never had another problem with the transmission (the engine blew, but the tranny was SOLID!).
Someone on here suggested that was the problem, so I had it towed to Aamco and they confirmed. At that time they offered free diagnostics, but I'm not sure if they still do.
I guess I just don't understand how the problem could be EGR related if you're not getting any codes at all. Between my F150 and my Explorere I've had plenty of EGR problems, and every one of them has set a code for some part of the system.
RBerry9511
07-24-2014 12:03 PM
facets
15
03-06-2014 02:09 AM
exc4x4
04-09-2011 10:06 PM
