Tranny fluid/rear differential change
I tossed the crappy stock tranny cooler last year and added a monster. I simply have my tranny lines running straight to it. Can I just remove the return tranny line and pump out about 3 qts. at a time then adding 3 new qts. repeating this procedure until it's new and clean fluid? Also, I haven't changed my rear differential fluid since I bought the truck last summer as the previous owner had it done about 20,000 miles ago. Should I check it also? I haven't really looked at it closely, how do I exactly check that and add if needed?
Where do I buy a tranny filter? Man, dropping the pan sure seems like a time consuming process. Mercon ATF is what I need?
There's a plug, front drivers side of the pumpkin about half way up. I believe a 3/8" ratchet fits in there. Fluid should be level with the bottom of that hole. Here's some good info. Welcome to guzzle's Ford PSD Web Page
I checked the rear differential fluid and it appeared pretty clean. I stuck my little finger in there and it seem to be between 1/4 and a 1/2 inch below the fill/drain plug. Should I add until it runs out of the fill hole a little? Also, I bought the truck last summer and don't know what kind of gear oil is in there, what kind should I add?
Check these out. Install a nice new cover and get fresh fluid all at once.
https://www.ford-trucks.com/forums/6...r-cheap-3.html
https://www.ford-trucks.com/forums/6...-08-cover.html
If you just want to top it off I believe Royal Purple says you can mix there stuff with any existing fluid.
