Two Stroke Oil Test
Two Stroke Oil Test
Nothing scientific here but I just got back from a 1311 mile trip pulling my 27' 5er. Fully loaded we were 17,000 lbs. We traveled mountains and flats and about a hundred miles solo doing a little sight seeing. I used 1 oz. per gallon Wally World two stroke oil and my usual 1/2 oz. per gallon of White jug Power Service.
My overall MPG was 11.67 per gallon, traveling 58 to 62 MPH. The overall weather for the trip was fair and I probably traveled a little slower than usual because of high fuel costs. I think my overall mileage was higher than usual but can't really say if it was the additives or a lighter foot. I do believe that I'm getting better lubrication and a quieter engine so I will keep up this treatment in the future. Average diesel price was around $4.70 but my last fill up was $4.99, ouch!
It has been said on here once before and I will say it again. The use of two stroke oil is not recommended to be used as a fuel additive. It causes increased nitration and oxidation levels in your oil. In simple terms, it makes you engine oil go bad sooner. I would stick with a fuel additive that was designed as a fuel additive. I will admitt that I tried it once, but that was before I found out about the harmful effects.
I have a hard time believing that adding a little oil to diesel will ruin my motor. It also makes sense that the fuel filter would appear much dirtier than normal because of the oil additive.
Kwikk, WW sells that oil by the gallon. Thats the way I buy it.
The last large car that I had I added a quart of ATF once a month to the fuel for almost 900,000 miles before I sold the truck, and it was still running fine. It did however have a different injection system than the late model engines.
I stopped using it. When I first added it my fuel economy jumped up....then I ran out and all the subsequent tanks have maintained the higher milage on straight #2. This truck has always been a 17-17.5 MPG summer vehicle and every tank this spring has been at least 18.1 and is averaging about 18.4. I have no explanation for it other than I did the 140v. IDM mod about the same time I added the first tank of two cycle.....
Memorial day weekend I put 400 miles towing an empty flatbed and got 17.3, then on he return trip I got 15.4 with a 96 Grand Marquis on the trailer.
I don't know what changed about either the truck or the fuel....but I'm happy about it.
white Buffalo
90
10-27-2015 04:01 PM
mudsmokinstroker
05-11-2014 04:26 PM
98SurplusExpy
09-29-2010 07:29 AM
