Door weatherstriping, doors too tight now
I installed new door weatherstripping on my 67 4x4 highboy. The doors are hard to close. Will these break in and get easier. I even adjusted the hinges and strikers to ease it up a bit, but its still a hard slam. Any ideas out there. Thanks. J. Vorhies
I had the same problem with my '78 when I changed the weather stripping. I had to very slowly and carefully take it off and and re-install it very slowly making sure it was exactly in the right place. Its was a pain in the a$$ and its still not 100% right but a lot better. I think buying a very good quality weather strip makes a lot of difference and its usually only one or two small spots in the stripping that makes the door hard to close
Give it time it takes several weeks for the seal to break in. It hasent been compressed to fit the contour of the door I did mine several years ago the doors shut like new type sound but takes very little effort to close nice today.Try not to mess with the door adjustment much or you,ll be readjusting them again after the seal has set to door.
Paraphrased from the Ford instructions that used to come with door weatherstrips.
After installing the weatherstrip, use masking tape liberally to hold it in place, especially at the corners. Close the door till the latch just touches the striker plate. If the dome lamp stays on, remove the bulb.
Clem's Cousin
06-09-2016 09:58 PM
Cabledude
08-21-2013 05:39 PM
truckmonger1
1999 to 2016 Super Duty
05-13-2010 09:41 AM
76F100guy
21
11-04-2009 03:52 PM
