93 ranger power windows don't work
Old 05-22-2008, 09:19 PM
ozzy460's Avatar
ozzy460
ozzy460 is offline
93 windows quit one day, both at same time, been down for a year, any ideas or should i just convert to manual?
Old 05-22-2008, 10:32 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
could be the switches or the relays. Do they do anything at all? Did you check the fuses? if all else fails you can go direct from a hot source and see if they go up that would put you into checking the above. Use a continuity tester to check the switches, easiest is to check for 12v at the wire harness with the door panels off, then 12v at the switches. if no power at the 1st check point go for the relays/fuses. also make sure to check the grounds for good connection.
jte1998
01-12-2017 09:01 AM
Joshs 93
07-06-2016 08:21 PM
bf5113x
10-19-2015 07:02 PM
boggerted
03-18-2010 02:32 PM
DuallyDad
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-23-2004 01:36 AM
Quick Reply: 93 ranger power windows don't work
