What is this plug for in the photo. It's the one on the right with two wires. There is nothing plugged into it. It is behind the kick panel to the front of the passenger side door.
Yep, there's a harness going back up on my 97. There's also some insulation behind the trim panel that my 95 F-150 doesn't have. Is this a diesel thing, or a 97 thing?
Its the source. Black is hot with running lights, brown in ground. pretty sure double check before quoting me I have not checked it in years. if the truck has factory cab lights it runs up the passenger side A pillar to the lights, from this plug. I have used this when installing mine and others. alot easier then pulling dash apart and tapping wires.
