polarizing generator
hey guys,i have a 58 f100,292.i took the generator off to paint the engine and generator,put it all back together,cranked it a few times over a few weeks.then battery was weak,had to jump start.got to thinking maybe i hooked the two wires on top of generator up wrong,swapped terminals ,did fine another few weeks,battery weak again.now i am wondering if anyone nows which wire goes where on top of generator,two wires come from regulator,and how to correctly polarize generator if i had it wrong.thanks. stony.
I got this from mtflat awhile back;
Polarizing a Ford Generator
I can outline the procedure for polarizing the thing. With the engine off, at the regulator, remove the field (F) wire and briefly touch it to the batt (B) connection. You should see a small bluish spark. Re-connect the field wire and you're done. This is per the shop manual.
Do not use a jumper wire - you can cause damage.
Trouble for googling for the info, the older 3 brush gen's with a cutout use a different procedure for polarizing and you'll find a bunch of confusing info.
Bobby
Bobby
cadougherty_67
07-08-2017 10:31 AM
F250Rob
01-18-2017 11:21 AM
jvmcc
09-27-2016 11:19 AM
F250Rob
20
02-18-2016 08:05 PM
sciondude09
03-15-2009 05:59 AM
